Edelbrock TBI intake
Car: 1991 Camaro RS
Engine: Stock 305 TBI
Transmission: Stock
I just upgraded to a full exhaust, along with ultimate TBI mods and a new fuel pump. I can get a Edelbrock performer TBI manifold very cheap right now, would I see any kind of gains if i went to the trouble of putting it on? An LT1 cam is in the future once I get chip burning sorted out, but would it do anything for me with my car as it is now?
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
You should do it. When I put one on I already had exhaust, ignition, and open element. I noticed an improvement in the upper RPMs. Granted, it is not a HUGE improvement, but its an excellent intake that is a true direct bolt on. It will surely help in the future for a cam and head swap.
Car: 1983 G20 Chevy
Transmission: 4L60
I am making plenty of HP with the stock manifold. I had sealing issues with the particular edelbrock intake I choose and sent it back. Could have just been that intake as others I have used in the pas sealed just fine.
Car: Trans AM
Engine: 305 TBI LO3
Transmission: W/C T-5
Axle/Gears: 3.42 Open
do it, i have one on my car as well as ported heads, a cam, and high flow cat and a dynomax. it really helps when gettin on the highway
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Originally posted by Fast355
I missed that you could get it cheap. Get it, those aren't cheap!!!!
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
Originally posted by ajbutowicz
So 35 bucks is a good deal? hahahaha, good to know people that are sick of TBI stuff...
Just let me know where you can get it for $35 first. Then give me a day or two.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally posted by ajbutowicz.I just upgraded to a full exhaust, along with ultimate TBI mods and a new fuel pump. I can get a Edelbrock performer TBI manifold very cheap right now, would I see any kind of gains if i went to the trouble of putting it on?
Originally posted by ajbutowicz.An LT1 cam is in the future once I get chip burning sorted out, but would it do anything for me with my car as it is now?
Duration = :lala:
Originally posted by MikeDirntRulez.Horrible deal... don't buy it. Just let me know where you can get it for $35 first. Then give me a day or two.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would buy if if you can get it that cheap. This intake has the same basic design as the performer carb intake. It can be bored to accept a 2" TBI unit as well. It is also a direct bolt on and nothing needs to be relocated, spliced or shared on the intake. This is a *** intake for a first time swapper.
There is nothing wrong with an LT1 cam. Often times "better" doesn't mean squat if you can tune it or have the heads to accomodate it. An LT1 cam swap is agreat mod seeing how you can get one for less than $40. I got one for $5.
Car: 91 Firebird Green
Engine: SBC L03 - TBI 5.0L V8
Transmission: WC T5
Since Edlebrock sends you a new chip with proof of purchase, I am thinking about buying one of these intakes, and a an underdrive pulley kit to free upa few horsepower. The intake would be about $350CAD (with chip) and I figure the pulley kit would be around $150CAD. On a stock L03 with 14x3" K&N element, what kind of power gain might I see? My guess would be about 30hp from the intake and another 10hp or so from the pulley...
Too much?
Too much?
Car: 1991 Chevy Camaro
Engine: 305 TBI
Car: '90 RS
Engine: 377 LSX
You will only see a tiny bit of power gains. The only way you would see 30+hp is with a cam swap and extensive chip work. You are at the point now where it would be wise to get into chip burning. Off the shelf chips won't cut it and you can get more out of the mods you have with it.
86IROC112
Aug 17, 2015 02:00 PM
