Thorttle response delay problem
Old May 9, 2005 | 06:54 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Engine: Stock 305 TBI
Transmission: Stock
Hey everyone, troubleshoot time.
I Just put my full exhaust on and when i nail the throttle it has a 3-5 second delay before it really goes. It brings the rpms up a little but there is just that long delay. Any ideas, needs more fuel pressure maybe?
Old May 9, 2005 | 07:28 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Increasing the fuel pressure should help a little, but you really need a custom PROM. The stock tune just can't handle much more than an open element, let alone full exhaust.
Old May 9, 2005 | 08:00 PM
90FormulaWS6's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
do you have an auto or a manual? 3-5 seconds is a long time... im assuming auto, it might be time for a rebuild your trans is slipping
Old May 9, 2005 | 08:26 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You may want to play with your fuel pressure and base timing. Those should help take away some lag caused by headers. Chip work will correct all problems that some people see with headers. A full exhaust can change the volumetric efficiency on these cars up to 10% which will in turn throw off the stock tune.
Old May 9, 2005 | 09:01 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Transmission: Stock
Trans grabs just fine, its just a problem like, with the engine pull kicking in... i was thinkin more fuel at a minimum, gettin into chip burning soon anyway.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
Stryker412
Sep 7, 2015 09:11 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
