Need some answers about TBI.
Old Jun 7, 2005 | 07:28 PM
biff85ta's Avatar
Car: 04 Vette
I have just purchased my first TBI car. I have a TPI car in the garage but it is slightly broken.
Anyway here is my problem. The injectors do not fire. They have been tested with a noid light and nothing happens. Where do I need to start looking to fix this problem?
Old Jun 7, 2005 | 09:25 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Just out of curiousity, what year is the car?
Anyway, first thing I'd do is check for spark. That can rule out a lot of possible things, either way.
Old Jun 7, 2005 | 09:39 PM
biff85ta's Avatar
Car: 04 Vette
He keeps saying 87 and I didn't think to check while I was there but I would bet it is an 88. (seller owns a used car lot and has several f-bodies of his own) I should have the car home this weekend so I can check it out better.
Old Jun 7, 2005 | 09:59 PM
Gr89RS's Avatar
Car: '02 Z06
TBI wasnt released until 88 so it probably is an 88, unless someone swapped in the TBI
Old Jun 7, 2005 | 10:04 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
There are several things that will cause the injectors not to fire: Lack of power at the unswitched + side of the injector connectors, dead module, dead p/u coil, lack of DRPs from some other problem, dead injector drivers, wiring faults, bad grounds, just to name a few. Does the fuel pump come on when your cranking the engine? If no pump, then the problem is likely within the dist. itself. I even had a faulty ground due to a dirty dist. base that caused a no spark or fuel problem.
Old Jun 7, 2005 | 10:17 PM
biff85ta's Avatar
Car: 04 Vette
Thank you that give me plenty of stuff to check out when I get it home.
Old Jun 11, 2005 | 07:38 PM
biff85ta's Avatar
Car: 04 Vette
Well I got it started. It turned out to be a plug not plugged in on the ignition module.
Old Jun 11, 2005 | 07:40 PM
Gr89RS's Avatar
Car: '02 Z06
Falcon50
Aug 22, 2020 03:26 PM
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
