Fuel Pump : (....
Car: 91 Camaro RS
Engine: L03 chip, airfilter,dual exhaust..m
Transmission: 5-spd
Fuel Pump : (....
I think my fuel pump went out.
Is there a cheeper higher pressure unit aftermarket out there?
Is there a aftermarket unit that fits out side the tank?
Thanks,
Mark
Thanks,
Mark
Car: 88 Camaro RS
Shifty recommended me the Walbro line of pumps since mine is going out as well. Your stock pressure regulator will work fine with these pumps. A stock GM pump will run you about 80 bucks. You can buy a kit from this site that includes the pump and all the parts needed for the install for about the same price.
Auto Performance Engineering
A friend of mine installed an external pump and drawed through the stock pump and it hasnt caused problems. (MSD external pump) This was my original plan but shifty convinced me it would be half-*** NOT to replace the intank pump.
Car: 91 Camaro RS
Transmission: 5-spd
Auto Zone has a Bosh replacement for $50 and a off brand for 40 something.
It's really hot out here and I have a autocross next Sunday and I got a one piece welded stainless steel exhaust, So dropping the tank will be a real beach.
I'm hoping some one will see this thats installed a external pump, and can give me some pointers. also maybe a pump with a little more pressure would be nice.
Mark
Mark
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Click on the link above and select one of the GM pumps. You will have it to your door in less than 4 days (got mine in 3) for $97. It will supply enough pressure and flow to feed a multitude of engine set-ups. You don't want to have to change it again if you plan on making more power down the road. The stock pump is very inadequte.
Car: 91 Camaro RS
Transmission: 5-spd
I made a access hatch to pull pump out from top worked great.
I installed a stock Bosch pump : (
From what I've read I need about 13- 13.5 psi, will a stock pump do that?
Thanks,
Mark
Thanks,
Mark
Car: '90 RS
Engine: 377 LSX
Car: 91 Camaro RS
Transmission: 5-spd
the L03 is stock with open airfilter and dual exhaust (no cat)
I think the next move will be to check regulater for psi at intake? make sure its getting what it can.
Mark
Mark
Car: '92 Camaro RS
Engine: LO3
Axle/Gears: 2.73 open diff
I tend to stay away from off-brand fuel pumps like you'd find at AutoZone. They don't last very long, and they whine like crazy when you get low on gas. I would feel much safer going with a GM pump.
Car: 91 Camaro RS
Transmission: 5-spd
Gez...now you tell me. I suppose the Bosh was made in China. I wonder if the GM pump would of been worth the extra money?
Mark
Mark
Car: '92 Camaro RS
Engine: LO3
I'm not sure about the Bosh one, but it sounds like you could have done worse if there was an off-brand pump for $40, at least you didn't buy that one. Who knows, maybe you'll have good luck with the Bosh.
Car: '90 RS
Engine: 377 LSX
Don't go with off brand of GM pumps. Both are unreliable. For the same price you can get a Holley or Walbro (same pump) that will reliably supply more power than you can think of.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
