changed fuel pump, still won't spray? need help ASAP
Old Aug 8, 2005 | 07:40 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
on TaTurbo's 82 Z 28 Crossfire.
injectors wouldn't spray, checked fuses, couldn't here the pump run, replaced pump, can hear it run, but no spray at the injectors? could it be a clogged fuel filter? car has 45,000 miles, and there was a little crap in the tank.
Old Aug 8, 2005 | 09:14 PM
weberflorida's Avatar
Car: 1991 Camaro Z28
Did you check the fuel pump relay fuse or something like that. I should be on the passenger side inner fender I am thinking.
Bill
Old Aug 8, 2005 | 09:33 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I thought only ford had those?
anyways, just replaced fuel filter, still a no go.
Old Aug 8, 2005 | 10:09 PM
I know that I have a fuel pump relay on my suburban that is a tbi and I have a fuel pump fuse on my camaro that is on the passenger side fenderwell. If you do a search I remember seeing pics of it on here some where. I think that it was shiftycapone that put it up for a few dudes a while ago.
Good luck brother
Old Aug 8, 2005 | 10:18 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I can hear the fuel pump run, shouldn't be a relay or fuse then
Old Aug 9, 2005 | 12:45 AM
STRIFE69's Avatar
Car: 91 camaro
Engine: 305TBI
Transmission: 5 speed
You check the wires to the injectors to see if they getting power?
Old Aug 9, 2005 | 07:12 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
You will likely need to check for flow at several places along the line (not fun, i have done this before....)
It will probably help to have a friend help with this, get a good bucket to collect any fuel that comes out. Start close to the tank (easiest way here, is to disconnect the rubber line that is the pressure line.) make sure that your new pump is actualy getting fuel up and out of the tank. have a friend turn the car on (do not try to start it), if the pump is functioning properly, it will pump some fuel out. If it doesn't, you pump is likely the problem, if it does, you get to start looking for clogged lines. The next place I would check, is the very front of the system (this will eleminate the injectors, or pick-up sensor as the problem). Disconnect the fuel line form the throttle body, same procedure, let the system prime, you should get fuel flow out of the feed line, if you do not, the clog is somewhere between pump and the point you do not get fuel, you will need to start tracing the fuel line back. This is pretty straight foward.
If you DO get fuel at where the feed line enters the TB, you can check and make sure you are getting some on the return side (you should, as chances that the clog is actualy in the TBI unit, is unlikly.) In which case either you injectors are not firing, or they are not being told to fire. This is where a noid light would be very handy, as you can check to see if they are getting a signal to fire. The pick-up sensor in the dizzy is the most likely cause, as probably the first place to check.
Old Aug 16, 2005 | 08:01 PM
bwidner1's Avatar
Car: 1992 camaro rs
Engine: 305 tbi
dewey are u talking about the pick up coil, as I am having this same problem
Old Aug 22, 2005 | 07:05 AM
swap350tbi's Avatar
Car: 91 RS Camaro
Engine: 350 TBI
vic_v8,
I think you need to check to see if your plugs are firing. If not then go to the dist. and start checking there. I would pull up "need help asap" by bwidner1 in TBI, he has the same problem follow along with the trouble shooting that has been sent to him maybe there is something there that will help you with your problem.
Good luck.
swap350tbi
Old Aug 22, 2005 | 03:12 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
sorry, guys, I already fixed it, turns out I crossed the wires
Old Aug 22, 2005 | 08:31 PM
Nice dude. LOL!! At least it was a simple fix right?
Bill
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
