Difference between rochester "306" and "310"?
Old Aug 29, 2005 | 02:58 PM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
I've got the 306 in my 3rd gen. I bought a 92 suburban lifted on 35" tires and wanted to give it more kick. It's got a 60,000 mile gm crate motor in it. The TBI has 310 cast on it. It also has only 3 vaccume ports on the front, versus the camaro's 4.
What is the difference? What lb/hr injectors did those models come with?
Thanks!
Old Aug 30, 2005 | 08:14 PM
nidyanazo's Avatar
Oh come on.......
Seriously............
Old Aug 30, 2005 | 08:29 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The suburban and f-body should have the same size TBI but with different injectors. You won't gain anything by swapping units. It would be easier to just change the injectors and do the chip work to make them work proper.
Old Aug 30, 2005 | 09:50 PM
nidyanazo's Avatar
I am going to swap on the camaro's tbi, with the burban's injectors, since I've already "ultimated" the one on the 'maro...
I read someone's post where they called the ultimate tbi mods the "unlimited" tbi mods.....Sounds cooler
Old Aug 30, 2005 | 10:26 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
The thirdgen TBI unit is different from the one on my FSC.
The ONLY diference I have been able to determine is that extra vac port. I misplaced teh vac diagrams, but I'm sure it only for something relatively unmeaningful (like the little flapper in the stock air cleaner or something along those lines?)
Other than that the units are exactly the same, don't worry about capability problems for modification.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
PurelyPMD
May 5, 2016 04:57 PM
69GTOby
Apr 18, 2016 02:34 PM
Scorched1984
Sep 15, 2015 03:42 PM
J.C. Denton
Sep 8, 2015 05:35 PM
