Dead Fuel Pump
Old Aug 30, 2005 | 05:47 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Dead Fuel Pump
For those wondering, an external fuel pump will pull fuel out of the tank, through a dead in-tank pump. Mine died, I yanked the pump from a Dodge Conquest, put it inline under the hood, jumped hot-in-run juice to it from the coolant fan relay, and she runs good as ever.
Old Sep 1, 2005 | 12:22 AM
NEEDforSPEED's Avatar
isnt that makeing the pump work harder?
Old Sep 1, 2005 | 06:58 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
did you put a pressure regulator on it to see what the pressure is
Old Sep 2, 2005 | 12:44 PM
STRIFE69's Avatar
Car: 91 camaro
Engine: 305TBI
Transmission: 5 speed
might work well now but I believe the pumps are more designed to PUSH rather then PULL. Where is the Factory location of the pump on the conquest?
Old Sep 2, 2005 | 12:56 PM
weberflorida's Avatar
Car: 1991 Camaro Z28
Yeah that is pretty common man. A lot of people who convert to a carb at least in my expierence and friends expierences we just put an external pump next to the tank and pull through the old pumps. I think that is also what the guys with the large turbo engines do. Anyhow, right on with getting your car running. That is a good feeling always.
Bill
Old Sep 2, 2005 | 12:57 PM
As for the fuel pressure regulator that is on the TBI and I seriouly doubt that he bypassed that. I don't know if you can. I am sure that he is running the same pressure as before.
Old Sep 3, 2005 | 06:53 PM
Car: 1992 RS
Engine: Carbed 350
Yes, I did not bypass the fuel pressure reg. The pressure is close to normal - I had 13psi at idle before, and now I have 11, so I suppose the external pump isn't doing AS good a job, but it got her home, and will get her around until I can get a better fix.
The only other thing I notice, is that I have to leave the key to ON for a few seconds before I start it, or it won't start - takes the external pump longer to get the fuel into the TBI I suppose.
But again, it got me home, and it runs as well as before.
Old Sep 3, 2005 | 10:55 PM
At least you got home brother that is all that matters. :0
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
