Late model 454 tbi owners, have a q.
Old Sep 11, 2005 | 11:48 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
For those who got the later 454 tbis from the yards...
Did any of you notice any sort of actuators hanging off the tbi or mounted to the throttle near the tbi, other then the usual stuff?
Old Sep 12, 2005 | 07:08 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Some have governors on them. Mostly from the heavy duty truck applications.
RBob.
Old Sep 12, 2005 | 07:33 AM
Car: 88 Camaro SC
Engine: SFI'd 350
I take it its basically just a servo of sorts that can override the throttle?
Old Sep 12, 2005 | 10:25 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I'm not real familiar with them. Thinking about where I saw info on them, can't really remember. Maybe one of the truck forums.
RBob.
Old Sep 12, 2005 | 11:45 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Im still chugging away with the late model PCM and the code has some PID control algos in it for that and I was wondering exactly what it was.
Old Sep 12, 2005 | 03:26 PM
Ronny's Avatar
i have the 1995-1996 GM TBI. i removed it. not sure what it purpose was. possibly a governor? appeared as a vacuum pull off or vac assist?
Old Sep 12, 2005 | 03:36 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Did it actually have vac lines going to it?
Yes, its purpose appears to be as a governor.
Old Sep 12, 2005 | 03:38 PM
Ronny's Avatar
it is two years ago but i will suggest it did have vac.. maybe it prevents the butterfly from snapping shut too quickly. that is a WAG.
MustangBeater20
Oct 29, 2022 09:20 PM
louishenry
Aug 28, 2015 09:41 AM
Jote4805
Aug 25, 2015 06:11 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
