Actual Top Speed?
Old Sep 26, 2005 | 09:13 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Actual Top Speed?
What is the actual top speed of a 91 RS L03 with a 700R4 and a 2.73 rear end, factory? I mean if you have pretty long strech. I know about the speed cut off (which my car seems to lack....) but what is the vehicle capable of? Thanks.
Old Sep 26, 2005 | 11:20 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
THE SPEED OF LIGHT
I am thinking with few mods 130 is not out of the question. I had my pegged a lot and it was still going. Of corse I have few things done to it.
Old Sep 27, 2005 | 02:03 AM
SchwarzCamaroRS's Avatar
yeah, somewhere around there im sure... ive gotten mine up to about 140, but it has a 350 now too...
Old Sep 27, 2005 | 08:29 AM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
140 if you can get rid of the 700r4's need to shift into 3rd at over 2/3's throttle.
-chillen
Old Sep 27, 2005 | 08:39 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I have had mine down to the MPH on my 110 speedo and it was still pulling some. So, I replaced the 110 with a 145 from a 1990 IROC. Never tried again after that. My new ASCD SS hood does the little fiberglass bounce about 50, so... Can you get hood pins for these cars?
I wonder what you could do with a T56 and 3.23? More or less?
What do you mean by: "140 if you can get rid of the 700r4's need to shift into 3rd at over 2/3's throttle." ?
Old Sep 27, 2005 | 08:45 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
A corvette/van/caprice TV Sleeve and Plunger. It will let you hold overdrive at high speeds. That being said, my bone stock 4 bbl carbed 305 would pull my giant brick to about 110-115. I could imagine that your more aerodynamic car combined with the more powerful L03 TBI 305 would move better than that.
Old Sep 27, 2005 | 09:28 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Hehehe. Sweet van motor, man. I may have to try building one like that. How much you got in it?
I know this is a Honda, but we were in Orlando this summer and I was driving my brother's Oddessy. We got behind my dad by a several hundred yards because of the traffic. (He is driving my mom's 5.7L Chevy Express 1500 conversion van) My brother and his wife are ribbing me for being behind, they say I need to catch up or I'll lose them. Not in a nice way, but a joking/sarcastic manner, insulting my driving abilities. So, I scan the area for cops, stomp it to the floor, and don't let of till I get behind my dad. Somewhere in the 6-8 lane changes, I looked at the speedo as it swings past 105. That was about 2/3's of the way to my dad, so I never looked back at it. That thing weaves in traffic pretty well.
They never told me to catch up the whole trip, but they did let me dirve....
Old Sep 27, 2005 | 10:12 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Not much. $800 for 245 RWHP. Take a look at what it is in though.
Old Sep 28, 2005 | 02:11 AM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
Transmission: 95 T56
Axle/Gears: stock 10 built, yukon diff, 4.10
you guys wont believe this. but not to long after i did the 5-speed swap in my bird. i took it down I-95 and i pegged the speedo at 140. but now for the kicker. i knew my speedo was off but i didnt know how much, so the next i drove along side my dad and found out how much my speedo is off. its off by ten. when im doing 60 im actually doing 70. with that being said. that means that i was doing 150. .
Old Sep 28, 2005 | 02:46 AM
they are graduated... so its off by 10 @ 60mph... its probably more at higher speeds... when mine says 70 im doing 60, but at 100 im only doing 82.... so its 10 off @ 70 and 18 off @ 100...
Old Sep 28, 2005 | 03:16 AM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
ok im not a math wizard actually i plane out suck at math. correct me if im wrong. by what your saying, does that mean i was going faster than 150?
Old Sep 28, 2005 | 03:27 AM
quite possibly... my rearend swap put my speedo gears at 18% high... so im going 18% slower than my speedo says... yours seems to be the opposite... yours looks about 16% positive... so by math, if you are reading 16% high, then you were actually going about 162.4... i doubt it though... i dont think youve got enough horsepower to push that 3400lb car that fast unless you were drafting someone... lol or going down hill...
Old Sep 28, 2005 | 03:30 AM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
no i wasnt drafting. i have 3.42 gears, with the 5 speed. but i dont know whats in the 5 speed. as far as horsepower. its a lo3. granite its not stock. but who knows. i guess the only wayt to find out is get the right speedo gears and run it again.
Old Sep 28, 2005 | 03:41 AM
the final gear in your T5 is probably a .63... it could be a .75. If its the .63, your speed @ 5000 rpm is 179, so at about 4500rpm you would be around 161-162... if you have the .75, you were barely hitting 150 @ 5000rpm but im not sure if a stock LO3 has enough horses to push the car that fast with the tire friction, drag co-effecient and wind resistance.. maybe 150mph, on a good day with wind headed the same direction as you...
Old Sep 28, 2005 | 03:46 AM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
its not a stock lo3, and i think i was about 5000 rpms. i cant remember exactly. but still if the car was going 150. thats haulin a$$. i dont think ill attempt that one again at least not until i get suspension work done.
Old Sep 28, 2005 | 03:54 AM
well good luck man
Old Sep 29, 2005 | 08:41 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Hey, SchwarzCamaroRS, what about a LS1 with about 350 and a T56 with 3.23 gears? What could hit in theory with that setup?
Old Sep 29, 2005 | 12:37 PM
yeah, easy
Old Sep 29, 2005 | 12:47 PM
wellington's Avatar
Car: 83 firebucket
Engine: less then a geo
Transmission: 5speed crap box
my bucket did 95-100 when i first bought it.
and that was with 140,000 miles of bad fliuds and neglect.
i bet i could get it up to 110 on a good day.
Old Sep 29, 2005 | 01:15 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Yeah, easy
What do you mean? I think I messed up the question. I wanted to know what you thought I could hit with a 350 hp motor, a 6 speed and 3.23 rear gear. Sorry.
Old Sep 29, 2005 | 02:00 PM
CrimsonDragon's Avatar
Car: 89 IROC - 85 Z28
Engine: 350 / 305
Transmission: 700R4 / T5
Axle/Gears: Stock
I hit 140mph with mine. Funny thing was how low we were sitting at speed with the aerodynamics working. I'd say it pushed us down 2- 3 inches at that speed. Out here we have some backroads with long stretches, no traffic, and no cops so I have opened her up on some clear/sunny days. One thing my Highway Patrol friend warns though, at that speed it can be a felony and most importantly have a lot of room to slow down as that is what bothers him on high speed pursuits. Anymore, he says, he'll only chase people up to 100, then let them go. He has seen too many high speed crashes. By the way, he has seen ALOT of our ThirdGens smashed up over the years and he says that they are good cars because they hold up well even in a head-on. A couple of years ago, a lady was hit head on by a Honda Accord while driving her Third Gen. She walked away and the other lady died. Anyway, cool, clear and flat - 140 seems achievable, but make sure you can stop. Replace those old rubber brake lines before you try it out!
Old Sep 29, 2005 | 02:10 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I plan to do a complete brake replacement with 1LE stuff and aftermarket lines before I bust 100 again. Rear disks, too. There is just too much stuff that can go wrong at high speed. A really good set of tires would be a good idea, too. My car is the only thing I have to drive and I have a bit of money in it to wreak.
Old Sep 29, 2005 | 02:26 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
it takes no time at all for my car to peg the speedo needle (91 110 speedo) on the trip meter...
but mine isnt stock.
Old Sep 29, 2005 | 03:39 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I had mine in the 140 range at PIR, I had more in it, but ran out of straight before I came into the turn 7-8 complex.
Old Sep 29, 2005 | 09:17 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I am getting there, slowly but surely. Is your car green, btw? Oh, wait. That Vert LS1 m6 had a 160 mph speedo...
I think 140 would be scary. My springs are all funky... lol
Old Sep 30, 2005 | 01:10 AM
you could prolly hit 160... maybe 170 with that setup... MAYBE... if the winds were right and you found a road long enough and flat enough... with the gears, 6000rpm in 6th gear is CRAZY fast... well over 170... with 3.23's and a 6000rpm redline, you could potentially go 170 with a 700R4... too bad you couldnt unless you had over 350/400 horses... lol
Old Sep 30, 2005 | 01:11 AM
i had mine about that @ Phoenix International too... but not the track... that long stretch of road in front of the track... haha i lived about 4 blocks from there...
Old Sep 30, 2005 | 06:34 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I have been thinking about save for the next 2 or so years and get a LS7 . That should get me to 170. 7000 RPM max. YEAH!!!
Wouldn't that be like 180-190 if I strap on a Paxton with about 10 lbs boost??
Old Oct 1, 2005 | 05:52 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
To fast for me i had mine up to 100 because a buddy kept bothering me to see how fast it was, and it was still pulling pretty good, i was starting to head up a hill so i gave him the excuse that the hill was to big for it to speed up anymore (yes i lied lol but, i think it would pull to 130 mph if i didn't have a 110 cut off(i think i do but, someone has put an unknown cam and taken the intake manifold off of it at one point in time so maybe they fixed the fuel pump shut off to, then again maybe it' slower you never know what they put in it lol....(not sure what was done to it).
1992 Trans Am
May 10, 2023 07:19 PM
Steve78LT
Feb 24, 2016 12:15 AM
gta90
Sep 15, 2015 04:00 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
InfinityShade
Aug 22, 2015 08:00 PM
