I need engine help bad!!!
I have tried searching but don't really know where to begin so if anyone can help me with this it would be great. I have a 95 tbi 350. The motor starts and idles great, if you ease into the throttle in park it revs up fine as well. The problem is if you just give it gas quickly it practically dies and starts sputtering and won't do anything until you let off. The motor came out a truck I already owned and it ran fine in it before the swap which I didn't do. Any help you guys could give me would be wonderful I need this thing to run by friday. It is all factory except none of the o2 censors are hooked up. I have heard that might be it but it seems to simple.
Car: 91 RS
Engine: 305 Tbi (L03)
Does it stumble when the engine is both hot and cold? O2's are only used when the engine is hot so if it does it when the engine is cold you should suspect something else.
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
check the vaccum hoses and egr too. Sounds to me like the last guy was right though tps sounds like it would be it. Btw those 02s need hooked up if you would like anything more than poor performance and gas milage (they realy do serve a purpose). Matter in fact metering the fuel is directly related to them which is the biggest difference between efi and carb. Anyways good luck with the problem and hope you fix it for tomorow!
Originally posted by kyles88bird
did u put a 350 prom in or do chip work?
Speaking of egr it could also be the other egr( Plugged exhaust).
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Your are not stupid if you can't see whats going on with the ecm, your just BLIND. FI requires working with the ECM no way around it. You can chase your tail for days and replace every sensor, but if you had a way to scan the ecm you could fix it in couple of hours, or even minutes. Other wise it's just guess and check.
A few things I ran into with FI motors in jeeps (I have a few friends with the swap). First off I assume you don't have a vehicle speed sensor hooked up? That causes problems, mostly with idle. What kind of fuel pump did you use? What is your fuel pressure? Also get your O2 sensor hooked up, that would help things greatly.
Well I am going to have the o2 censor hooked up today and get a new sensor, I have been told to get a heated one since it will be behind the collector.
It is running the stock fuel pump but I don't know if there is a pressure regulator on the lines. I may buy a pressure guage so I can monitor that. I was told to keep it around 14 is that correct?
I have a laptop and was wanting to find where I could download the program so I could hook my computer to my ecm and run my own diagnostics on it. Any help here would be great. Thanks for everything so far.
Car: 84' Monte
http://winaldl.joby.se/
Free software, you can build the cable for 5$, use the schematic at the bottom of the cable page. Or buy one from AKM for 50 somthin.
If your car originaly came with a 305 and you swapped in a 350 in its place you will need to use the computer or the prom for the 350 engine otherwise the engine will run lean, also make sure you get your 02 sensor hooked up, not having it hooked up will also cause problems.
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
is any1 Reading this whole thing?
The guy said it ran well enough to his liking before. Now it's not running good at all......
Anyways sorry to say i don't have any answers for you. I just figured i'd save you the hassle of reposting this, so others will hopefully see it.
