Fuelpressure issue again
Old Oct 12, 2005 | 02:24 AM
Spitfire's Avatar
Car: G20 van
Engine: 305TBI Supercharged soon
Transmission: TH400
Hi!
I want to get more fuelpressure and my target is about 20psi.
I have new external fuelpressurereugulator and pressuregauge.
I have removed orginal regulator. Pump ( Carter P7400) and fuelfilters are new. I still can't get over 14psi no matter what I do. Is it impossible to achieve over 15 psi with orginal pump?
Thanks!
Old Oct 12, 2005 | 10:03 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Fuelpressure issue again
Yes. You need a higher capacity fuel pump. The stock units are only designed to flow 12 yo 15 spi of fuel on a stock (low pressure TBI system) motor through stock fuel lines. Why do you need a fuel pressure increase? Are you tuning the car via the PROM to necessitate this change? If so you will need to upgrade to a TPI or Walbro pump.
Old Oct 12, 2005 | 12:08 PM
smikecq's Avatar
Car: 92 RS Convertable
Engine: 305 LO3
Transmission: 700 R4
I had the same problem get a larger in tank pump.
Old Oct 13, 2005 | 12:25 AM
Spitfire's Avatar
Car: G20 van
Transmission: TH400
Thanks!
I must buy better pump. Could someone recommend a good one? Is TPI and TBI fuelpump mounting exat same?
I'm mountig Eatons supercharger and Megasquirt to control fuel and sparking.
Old Oct 13, 2005 | 10:17 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Thanks!
The TPI and TBI pumps are interchangable. I would look at a Walbro pump. They are more relaible than GM pumps and typically cheaper.
Old Oct 13, 2005 | 10:54 AM
smikecq's Avatar
Engine: 305 LO3
Go to your local traditional auto parts store (CARQUEST, NAPA)
and look through there fuel pump book, they will have pictures and specs. That is what I did anyway.
Old Oct 13, 2005 | 01:52 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
He may have trouble doing that in Finland
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
