best way to clean out TBI system?
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: 700 R4
Axle/Gears: 273 rear end
i have to replace my intake and i wanted to clean out my tbi while it was off, but i dont know anything about tbi, and was wondering if i could just take some carburator cleaner to it?! what would you recomend
Car: 91 RS
Engine: 305 Tbi (L03)
Thatll work. You may want to try one of the cleaners designed to be used while the tb is still on the engine. Just soak it for awhile and brush clean.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I wouldn't soak the unit itself in anything unless you remove all of the sensors and such. You really only need some carb cleaner and a toothbrush. Clean out all of the vacuum passages on the bottom side of the unit. Make sure you keep the cleaner off of the IAC and TPS. If you do get some on the IAC make sure you wipe it down and put a small drop of clean oil on the pintle.
Street Lethal
Aug 13, 2015 08:28 PM
db057
Aug 11, 2015 10:11 PM
