Cleaning Intake Manifold??
Old Nov 17, 2005 | 11:51 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Hello all. By cleaning the intake manifold inside and out, getting rid of all that build up, will this take away my EGR problems. I replaced my egr with the dealerships one about a few months ago and im still getting the check engine light on the free way. I hate this crap man. I also replaced the silinoed too. should i also change my o2 sensor?? Its a bosh and it was changed about 2 years ago.. thanks
Old Nov 17, 2005 | 05:56 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Comon guys, I did the search and i know that bosh isnt good just need to clarify it. And i know that some of you have cleanded out your intakes one time or another. I just need some direction.
Old Nov 18, 2005 | 01:18 PM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
What's bosh? I'm not poking fun at you, but I think you're saying Bosch. I couldn't understand what you meant when you said bosh.
Also, what code is it throwing? Are you running too rich? Does your car bog? It might not be your EGR that's acting up. I thought I had EGR problems, cleaned out the manifold, cleaned out the EGR, replaced every damn sensor, and it turned out that I had a vaccum leak. Check your vaccum lines
And also, I think your O2 Sensor should be fine. Usually they last longer than 2 years.
Old Nov 18, 2005 | 02:06 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
thanks for the reply bro, I just did some troublshooting last night cause i finally got a hand held vacuum pump. It turned out to be a bad EGR silinoied. I went for a test drive and light hasnt came on yet. I heard that the bosch O2 sensors arent that good? I think im running rich cause of that sulfur smell out my exhaust. I had a new cat put in about 5 months ago.
Old Nov 18, 2005 | 02:32 PM
azblazer's Avatar
Car: 1979 K5 Blazer
Engine: Crate 350 - TBI Conversion
Transmission: TH350- NP205
With tbi unit removed look to the rear of the throttle bores and down a quarter inch or so....there are two small ports for the egr.
Mine were so plugged i used sea foam and small picks to clean out the ports...of course with the intake removed and it took 3 hours or so to do it. Sometimes you can take the mainfold to a local machine shop and have them throw it in there parts cleaning tank for a small fee but it doesn't allways remove all of the obstruction.
Doug W.
Old Nov 18, 2005 | 08:35 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Id definatly say your running rich. This will also destroy the cat in short order. The sulpher smell indicates very high temperatures being generated in the cat. Bosch O2s arnt that great, but they work. I have them on several cars, and they produce no noticable difference (better or worse) over the stock units theyve replaced.
What else does the car do? Does it idle poorly? Any other codes from the computer?
Old Nov 18, 2005 | 08:42 PM
1988-305-tbi's Avatar
i used to get code 32's on the freeway all the time, after my header install. I replaced the egr/and solenoid nothing helped until i got a new stage 2 prom from tbi chips. code 32 hasn't shown up ever since,
Old Nov 19, 2005 | 06:39 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Well the car idles ok nothing to bad, but i have notice that when im in a gear the idle seems a little bit rough.. I just changed the EGR solenoid and nothing still. I cant put my finger on it. I cant see why im running rich... Maybe i got a leaky injector?? Thanks guys for the responce. And the only code i get is the stupid code 32 Do you think my CTS is making it do that, making the computer think its cold?
deracer
Apr 11, 2016 12:04 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
