Controle module burnout
Old Dec 26, 2005 | 01:36 PM
bigozzyfan4life's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
I have a stock 305 TBI and when I bought the car the guy had replaced the controle module a while back. He said it needed replaced again because it went bad. The car would run good for about 15 minutes and then die and wouldn't start until it cooled down. After I replaced the module it fixed this problem. My question is, what could be causing these modules to go bad so quickly?
Old Dec 26, 2005 | 03:06 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Pleae let us know what module you are talking about.
The one in the distributor, the one under the passenger dash ecm or some other one?
More info to us = better chance of solving your problem.
Any GM part number on the module in question would also be helpful.
S-D
Old Dec 26, 2005 | 10:28 PM
Car: 1992 Camaro RS
Engine: 305 TBI
the one on the distributor, sorry about that.
Old Dec 26, 2005 | 11:28 PM
Car: 1991 RS
The only thing I know about that module is when it is being replaced it is important to use the gel (or whatever that goo is that is typically included with the module) when re-installing it.
The stuff must be smeared on the bottom of the module prior to installation on the distributor. This layer of material helps conduct and dissipate the heat that builds up in the module out to the aluminum distributor plate it is mounted on.
Without the stuff, the module will fry- just a matter of time and cause you all kinds of trouble. Sporadic electrical problems are even less fun than a crabby girlfriend (if that is possible).
I believe this person had a similar problem
https://www.thirdgen.org/techbb2/sho...tor+module+goo
Aside from that- parts stores are known to sell the occasional POS electrical part.
Best-
S-D
Old Dec 28, 2005 | 04:47 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Also, they are most likely the cheap modules which is why they are going bad so quick. Be sure to get a genuine AC Delco Module when you replace it. It will last much longer.
Old Dec 28, 2005 | 03:58 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The "goo" is Dielectric Grease - and a small tube of it should come with the module.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
Cleotiz
Sep 16, 2015 08:02 AM
TrevinE
Sep 14, 2015 03:20 PM
dbrochard
Sep 7, 2015 09:41 AM
