305 stroker kits
Old Jan 6, 2006 | 05:24 PM
gp423's Avatar
Car: 1989 Firebird Formula
Engine: LB9 305 tpi
Axle/Gears: open 2.73's baby!!
305 stroker kits
hey, guys, i havent been all that active on this fourm. but i have been reading this fourm for quite some time now. this is a great fourm that taught me a bunch over the months! i recently aquired a 1989 firebird with a 305 tbi and an auto in it, the rest is stock. ive always wanted to build up a 305 because of all the resistance about it and because its not very common.
after looking around online i came across a few stroker kits for $800-$1000 that would give me about 335 cubes depending on the overbore of the block. i was wondering if these kits are worth it and if they any good? i was hoping to get oppinions from people who have these stroker kits in their cars. i plan to build the engine up in a few months and try to create a mighty mouse on a budget! thanks for any feedback guys!
Old Jan 6, 2006 | 05:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you do a search for 335 you'll turn up more opinions than you'll ever want to read.
Old Jan 6, 2006 | 05:51 PM
gp423's Avatar
Engine: LB9 305 tpi
hmm alright, ill give it a try, i was seaching 305 stroker and i wasnt getting anything, thanks for the idea though.
Old Jan 7, 2006 | 08:17 AM
91RockS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI (L03)
Axle/Gears: 3.73 Truetrac posi
Get prepared to be flamed by the regulars on this board for wanting to spend $800-1000 to stroke a 305. I considered this a while back and came to the conclusion that you could move up to a 350 for equal or less money and have singificantly more hp, probably a good +100 hp. In the end, do what makes sense for your goals (hp, $$, time).
Old Jan 7, 2006 | 09:08 AM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
Old Jan 10, 2006 | 02:22 AM
iroc22's Avatar
The length of stroke in the 335 is not ideal for the bore size. Valve shrouding doesnt allow a whole lot of air in the cylinders and doesnt optimize cylinder fill for the power stroke. It just isn't a good idea. Go 350.
Old Jan 10, 2006 | 08:49 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
For 800$ to 1000$ you can get a 350 block, and then stroke it to a 383. A small block is a small block, you can't tell the difference from just looking at it, so why go through all the hassle and money to end up with something that doesn't run as well as a common 350 and not have anything to show for it. Joe blow at the local hang out isn't going to believe you have a 335 anyway.
mhatfield 14
Oct 24, 2015 07:48 AM
LittleFranks
Sep 17, 2015 12:22 PM
Mickeyruder
Sep 2, 2015 02:45 PM
bdads
Aug 24, 2015 06:01 PM
drathaar907
Aug 6, 2015 04:20 PM
