what would you suggest for my motor?
Car: 89 rs, bmw 325 is
Engine: 360 (.060) 2.5L inline six
Transmission: 700r4, 5-speed
Axle/Gears: 9 bolt 3.08 3.? limited slip
its a 350 block bored .060 out. stock crank and rods, with forged flattop pistons 4 valve relief. hydraulic roller cam with 264 intake duration 270 exhaust duration. .494 lift (intake) .501 (exhaust). 882 heads 2.02/1.60 i believe? roller rockers, and edelbrock air gap manifold. my question is what should i do for induction? i have a holley 650 right now, everyone says i should run my tbi though. is it worth it to go and get all of the stuff i need, or just put the carb on?
if it is worth it what do i need to do to get my motor to run the best?
thanks
kent
thanks
kent
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Do you have an emissions requirement?
If not, I'd run the carb - way too hard (IMO) to get the computer chips tuned right for the TBI stuff (unless you can do it yourself, and have the time for hours of datalogging and chip burning.
I'd think it'll also be very hard to get it all to fit under the hood with the Air Gap intake AND a TBI adapter plate.
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
If slightly better throttle response and about 3 mpg is worth it to you then go for it. You will HAVE to learn to burn chips, no question about it. If you don't have a serious interest in being able to tune your car with a laptop, then forget it and run the carb.
i do have emissions requirements, unfortunatly. carb would definitly be the easy, and cheap way to go. as far as getting everything to fit under the hood, i have a cowl.
fast 355 you really think that the cam is too big for my heads? sorry i also have a correction, my heads are 441, i have a set of 882s that i get confused.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1992 RS
Engine: Carbed 350
i have my heads worked to take the cam, i got the valve springs that comp cams suggested, hardened seats and bronze valve guides. i had the spring seats cut for these valve springs. i would fail inspection with a carb, but i fail now with my tbi on it. this motor as it is will fail either way.
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
If you go with a smaller cam, stick to TBI and have it tuned you have a much better chance of not failing.
There will be more work and time involved to get it right, but you can pass the sniffer, and get the better gas mileage as well as appear to be closer to stock for a visual.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
