Huge oversight
Car: 78 Caprice Coupe
Engine: 355
Transmission: 4L60
Huge oversight
Was planning on going with vortec heads then suddenly realized that it'll put my compression at something like 10.5:1 waaay more than I want. So now I'm thinking of going with the world product heads with the stock size chamber (76cc) but I don't know which ones to buy. The part numbers (from summitracing) for the closest I can come to a match are:
WRL-043600-1
WRL-042670-1
WRL-042770-1
WRL-043640-1
WRL-043640-2
WRL-043600-2
Which should I get?
WRL-043600-1
WRL-042670-1
WRL-042770-1
WRL-043640-1
WRL-043640-2
WRL-043600-2
Which should I get?
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
I've heard both 76 cc and 64 cc on the 350 swirl port heads.... but I've also not seen people carefully check to see what the casting number was (193 or 191 casting suffix, 350 heads), whether the pistons were dished, and whether the vehicle was a car or a truck.... and then post all that info together.
It would have been easier and cheaper for the factory/foundry to make a single chamber size (64 cc) on both the 191 and 193 castings for use in both cars & trucks, and then to use dished pistons to drop the CR on the trucks. But I've never been able to confirm that.
Engine: LO3, LO5
Originally posted by Fast355
Well EVERY 193 that I have run across comes in at about 65 cc, stock from GM.
Engine: 355
Transmission: 4L60
I thought only 305's got the smaller cc heads... How would I be able to find this information out for my car? Would it be in my service manual?
Engine: 355
Transmission: 4L60
Will do more research after work (on lunch break) but I did a quick search and found this...
http://69.20.110.81/index.asp?PageAc...D&ProdID=42937
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
That link you posted gives compression for the 9C1 car to be 9.6:1 and lists the heads as 65cc, that makes me think they're probably flat top pistons in that engine. Whereas the lower compression motors probably had the same heads but dished pistons.
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
My 93 FSM lists my compression at 9.8:1.
Too bad this thing uses dished pistons:
http://www.sdpc2000.com/catalog/514/...e-Assembly.htm
If L31s have about the same combustion chamber volume as my 193s, and I have flat top pistons, then I can use flat top pistons with L31s and still run 87 octane. That'd be nice.
Engine: 355
Transmission: 4L60
The link I posted says except 9C1 cars. Which would mean my engine as well as Kevin's. I think I'm back on track with these vortec heads though.
Engine: 305 TBI
Engine: LO3, LO5
They say "except police" because the engine:
1. has the low-lift peanut cam rather than the police cam (773 pn suffix, same as used on L98),
and
2. they don't want it used for warranty use in a copcar (even though it's an identical LO5 engine, other than the cam).
and
Engine: 355
Transmission: 4L60
Anyone know the stock head gasket size bore/thickness? It'd help an awful lot for figuring out compression differences between heads with a new gasket.
Car: 94 9c1 Caprice
Engine: LT1 (3-fity)
Transmission: 4L60E reBUILT
Axle/Gears: 3:08 POSI (out)
You can use the 64cc Vortec's.
I just happen to have the engine on the stand out of my 93 (LO5) it does not have a dished pistons they are flat tops. They do have 4 valve refiefs at about 5cc.
The pistons are .020 down in the hole, the gasket is .037 after compression by 4.1 bore. The 193's come in at 64ish cc like Fast355 said. With all that stated gives you about 9.83:1 by the Compression Ratio Calculator that I use.
If you want to change the CR alittle just use diffrent head gaskets, a .060 copper will be 9:32:1,
an .043 gasket (.041 compressed) will be 9.74:1
and a .015 steel shim will be 10.38:1
Car: 1983 G20 Chevy
Transmission: 4L60
Engine: 355
Transmission: 4L60
If you use the .015" steel shim gasket, with the .020" in the hole, that is about .035. You need a steel shim gasket that comes in at about .020 if your pistons are .020" in the hole. Most rebuilder pistons are .025" in the hole, combined with the .015 shim, that is .040. With .040 quench and higher compression you will actually have less of a chance of detonation than say .060 with lower compression.
Anyone have Desktop Dyno??? I'm trying to figure out the compression ratio calculator in it... not making any sense to me.
For flat top pistons without valve reliefs it gives four options
1) Head chamber volume (64cc)
2) Head gasket bore (4.2")
3) Head gasket thickness (.039")
4) Piston down bore @ TDC (.045") Added the 5cc of valve relief here
Gives a compression ratio of 9.73
When I try to do it the right way using option two
For dome, dish, or flat tops with valve reliefs I have five options
heres where I get lost
4) Piston down from TDC (?) value must be between 0.1 and 2.0 inches
5) Volume above piston (5cc)
I tried using a shim (.02 as mentioned) in the first set but it jumped from the 9.73 to 10.21 which seems a bit higher than I want.
Car: 1983 G20 Chevy
Transmission: 4L60
Here is my math on the 193s
Stock 350 bore and flattop piston with 4 valve reliefs (8cc of reliefs)
65 CC 193 Head
.020 in the hole((factory engine are about this)
.020 nominal compressed gasket 4.1" diameter (typical felpro shim which is identical to what would have come in the 9C1)
9.78:1
65 CC 193 Head
9.78:1
Car: 1983 G20 Chevy
Transmission: 4L60
You read that article too
I simply do my math by taking the piston dished volume and adding it to the head CC.
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Engine: LO3, LO5
Originally posted by kevm14
Damn, they fully spec out the cam in that thing. That would be useful for at least modeling the non-9C1 L05. What are 9C1 people supposed to do?
A 9C1 owner would have to swap cams.... which would technically void the warranty if they ever found out about the cam swap.
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
I know it's the peanut cam. I've just never seen the full IVO, IVC, EVO, EVC specs for it before. They are much more accurate in engine modeling than using the duration @ 0.050 or even advertised duration. See my post in your sticky thread.
