Carb to TBI
Old Feb 21, 2006 | 04:24 AM
blood006's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Carb to TBI
I have a 305 TBI in my 92. I am getting a 350 carbed to drop in it. Will the TBI off of the 305 work on the 350. The reason I want to keep the TBI is because I am in Germany and I want to bring the car back home with as little trouble as possible. If this will work can I just bolt it on or what mods will I have to do?
Old Feb 21, 2006 | 10:54 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What type of power will the 350 make? If it is not too wild you can run the stock TBI unit off of the 305. You will need to run a 350 TBI specific kock sensor and fuel injectors. You should really look into chip work and or run at least a caprice LO5 chip (assuming that 350 is very mild).
Old Feb 21, 2006 | 12:37 PM
blood006's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
It is a GMPP crate carbed 350 (used of course) w/ @ 250hp. I want to make this work very bad. Its hard to find that kind of engine over here for this cheap. If those mods you said would work where would I find them. Speaking of chips hows about one out of a vette. Would that work any better? Throwin out ideas....thanks
Old Feb 21, 2006 | 12:42 PM
blood006's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
If the carb to tbi wont fly where can I find out how to make the carb work. Also would I have to bypass the computer?
Old Feb 21, 2006 | 01:10 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
In the tech articles on the main page there is a write up on that swap.
I would find/buy a 350 caprice chip and use that for now.
Old Feb 22, 2006 | 10:59 AM
chesterfield's Avatar
Car: Pontiac
Where is back home? If you're bringing it back home to, say, California that carb idea won't fly with Ca emissions. I assume you need it to pass smog, right? You might want to post in one of the regional boards to find out what you can get away with in your area.If you put your TBI on it you'll need to modify 4 of your intake manifolds bolt holes IF the heads are pre 1987.
Old Feb 23, 2006 | 05:42 AM
blood006's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I am taking it back to Indianapolis, Indiana. I live 5 min. from the speedway. Dont think they care lol..
Old Feb 23, 2006 | 03:06 PM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
Axle/Gears: what ever stock is
OOHRAH HOOSIERS
Old Feb 28, 2006 | 09:50 AM
85blackberlinet's Avatar
Car: 85 berlinetta
Engine: none
Transmission: 700r4very soon t5
when i moved to stl they called me a *******
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
Billy Decker
Sep 4, 2015 03:46 PM
