Alright so I got my open element but what...
Old Apr 8, 2006 | 10:44 AM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
What is this refering to in the instructions. Its got me a little confused and I'm trying to do this in the rain...
<!--[if gte vml 1]><v:shapetype id="_x0000_t75" coordsize="21600,21600" o:spt="75" oreferrelative="t" path="m@4@5l@4@11@9@11@9@5xe" filled="f" stroked="f"> <v:stroke joinstyle="miter"/> <v:formulas> <v:f eqn="if lineDrawn pixelLineWidth 0"/> <v:f eqn="sum @0 1 0"/> <v:f eqn="sum 0 0 @1"/> <v:f eqn="prod @2 1 2"/> <v:f eqn="prod @3 21600 pixelWidth"/> <v:f eqn="prod @3 21600 pixelHeight"/> <v:f eqn="sum @0 0 1"/> <v:f eqn="prod @6 1 2"/> <v:f eqn="prod @7 21600 pixelWidth"/> <v:f eqn="sum @8 21600 0"/> <v:f eqn="prod @7 21600 pixelHeight"/> <v:f eqn="sum @10 21600 0"/> </v:formulas> <vath o:extrusionok="f" gradientshapeok="t" o:connecttype="rect"/> <o:lock v:ext="edit" aspectratio="t"/> </v:shapetype><v:shape id="_x0000_s1026" type="#_x0000_t75" style='position:absolute; margin-left:0;margin-top:.05pt;width:203.25pt;height:112.35pt;z-index:1' wrapcoords="-65 0 -65 21482 21600 21482 21600 0 -65 0"> <v:imagedata src="file:///C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\msohtml1\03\clip_image001.png" o:title=""/> <w:wrap type="square"/> </v:shape><![endif]--><!--[if !vml]--><!--[endif]-->
  • The Breather. You can either put the breather filter back on the breather tube using your stock breather, letting it stand freely, or you can purchase an aftermarket one and replace the breather tube with it.
Old Apr 8, 2006 | 10:50 AM
DM91RS's Avatar
Car: 91 RS
Are you refering to the valve cover breather?
Old Apr 8, 2006 | 10:55 AM
r0nin89's Avatar
Thats the thing i'm not sure but i beleive so. It's from our official Open element mword guide
Old Apr 8, 2006 | 11:17 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Go get one of these from the local Auto Zone, Napa, or whatever is in your area:
Example of a valve cover breather (Summit)
The next question is what did you do with the IAC?
Old Apr 8, 2006 | 11:22 AM
r0nin89's Avatar
Does this replace the tube from the left (facing the engine from front) valve cover that hooked into the old air cleaner?
Old Apr 8, 2006 | 11:50 AM
Cadillac's Avatar
Yessir.
Old Apr 8, 2006 | 01:53 PM
r0nin89's Avatar
Ahh duh. I'm too used to seeing an engine sit on a stand... You know the diameter of that hole because I bought an 1-1/4 I beleive and I can already see its going to be too big.
Old Apr 8, 2006 | 02:52 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
I would love to know what size that hole is, ive been trying to figure it out for 6 months now. I want one of those push in breathers, but im stuck with a cheap piece until i find one.
Old Apr 8, 2006 | 04:15 PM
a mack6's Avatar
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
The diameter is 3/4 inch. I know that the Mr. Gasket breather that has the 3/4 inch diam. neck has a huge grommit around it, which makes it impossible to fit. So keep in mind that you may need to purchase a smaller grommit along with the new breather (incase the grommit that comes with the breather is too big).
Old Apr 9, 2006 | 09:52 PM
r0nin89's Avatar
Talk about hitting nails on the heads before you even know the nails are there... I had to buy a new grommet after I bought a Mr.Gasket breather...
Old Jul 25, 2006 | 05:12 PM
jamessr's Avatar
Car: 92 Firebird
Engine: 5.0L V8
Transmission: 700-R4
Ok I'll chime in here cause I just finished my set up 15 mins ago
I purchased a 1" grommet from Summit. I measured twice, and came up with a 1" hole in my valve cover, not 3/4. So if he came up with 3/4 and I came up with 1" you might want to measure yours to be completely sure.
Part# TRD-6077 Trans-Dapt Performance Valve Cover Grommets: TRD-6077 - summitracing.com
Part# KNN-62-1160 Summit Racing - High Performance Car and Truck Parts | 800-230-3030
This should take you directly to what I purchased.
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
drumstixer
Sep 29, 2015 03:02 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
