would it help to convert to a carb
Old Apr 9, 2006 | 10:09 AM
lowgas&rubber's Avatar
Car: 97 b4c camaro
Engine: 350 lt1
I've heard from a few people when you get real serious with modding tbi you should convert to a carb. Would that help me any or is it a waste of time and money.
Old Apr 9, 2006 | 05:36 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What are your power goals and intended use for the car? If you have around 300 hp and use the car as a daily driver than staying with TBI is the way to go.
Old Apr 9, 2006 | 06:24 PM
Car: 97 b4c camaro
Engine: 350 lt1
Im gonna be using this as an almost daily driver and a weekend dragstripper. If I did go with the carb setup, which kind should I get 2 barrel or 4 barrel? And a small block intake with a carb setup or what? thanks
Old Apr 9, 2006 | 08:40 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I would keep TBI then. TBI will yeild better throttle response (during cold starts), fuel mileage, and the ability to read trouble codes. With the prices of fuel I would not use a carb'd car as a daily driver.
Old Apr 9, 2006 | 10:23 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
If it's a daily then you should leave it mainly stock (except tuning and bolt-ons like exhaust) IMO...
If it's not a daily then you know you will never be happy with your level of power. With that said, ditch it for a carb.
I pulled 20 mpg with a 355 carbed, worked heads, single plane, .488 lift cam, carb and 3.73 gears out back...
FI kicks *** but TBI and big numbers are like oil and water - they don't mix
Old Apr 10, 2006 | 12:10 AM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
If your car will ever see a drag strip don't even look at a 2bbl, unless you happen to be looking at 3 at the same time. I'm not sure what you meant by the small block intake question, but if you are running a small block engine then you are pretty much limiting yourself to a small block intake. A lot of people will probably steer you towards a carb, but if you browse around here you will find plenty of people that have had much success with TBI. I am personally looking forward to tinkering with mine.
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
andy74
Sep 3, 2015 08:41 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
