Double Barrel cool air intake from GM parts
Old Apr 16, 2006 | 07:06 PM
dirtfarmer's Avatar
Car: 1991 convertible RS
Engine: Lo3 305 TBI
Transmission: MD8 700RV
Axle/Gears: 2.73OEM to 3.08 posi disk underway
I know there are a ton of these mods but this one looks clean and is easy.
I got the parts from the junk yard and they were cheep. I got a few air ducts and stuff and headed home. This is what came out of all the parts.
I think I can post photos......
Well check it out.
Ron
Old Apr 16, 2006 | 08:55 PM
dirtfarmer's Avatar
Engine: Lo3 305 TBI
Here are some other photos.
The air intake on the bottom is simply the stock intake(from the junk yard) inverted. I made a little bracket to hold this in place. The added intake is the nose off the stock intake too. I cut it and then spot welded it to the intake. Cut a hole from the inside out and I got twice the air flow. GM made room for the original hose to fit in there so two fit in there easy. I took a tall filter cover(cal cover) from a 85 malibu TBI. I fits and allow the use of a taller filter. More air more filter...right
Well there you have it.
Ron
Attached Thumbnails Double Barrel cool air intake from GM parts-stacked.jpg   Double Barrel cool air intake from GM parts-hoser.jpg   Double Barrel cool air intake from GM parts-lower-floor.jpg
Old Apr 16, 2006 | 09:11 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
That is actually not too bad of a set-up and I can't recall if I have ever seen one like that. I would try to route that one duct up out of the engine bay. You kinda have it in a poor location. I see that you have a STB which makes running a traditional f-body dual snorkel unit diffucult. This may be a great alternative.
Old Apr 16, 2006 | 09:19 PM
dirtfarmer's Avatar
Engine: Lo3 305 TBI
I'm glad you like it Shifty.
Which hose do you refer? The lower one?
Is it too close to the motor you think?
Old Apr 16, 2006 | 09:44 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I am refering to the one that is not bolted down in the stock location. You can't see it in your final assembly pictures. I would try to route it as close to the other one as possible. Having it close to the engine like that doesn't promote "cool"/ambeint air ingestion.
Old Apr 16, 2006 | 09:57 PM
dirtfarmer's Avatar
Engine: Lo3 305 TBI
Ok. I see what you are saying. I think I could tie that up to the strut support (Zip ties)and get it away from the motor more.
Good idea
Old Apr 16, 2006 | 10:00 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
IMO, open element works better and is easier...
Old Apr 16, 2006 | 10:03 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I like that setup too! I never thought of it...I have a regular dual snorkel setup (that looks like Robot arms)...your idea is something to try perhaps...might get a little cramped in the engine bay with all the ducting however...hmm
Old Apr 16, 2006 | 10:04 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
Open elemtn ftw...oldschool
Old Apr 16, 2006 | 10:07 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
And not smog legal either
Old Apr 16, 2006 | 10:08 PM
They work, that's one reason so many fast cars run them.
Old Apr 16, 2006 | 10:09 PM
30 second job to put the stock one on for inspection and testing once a year
Car: 1988 SC Camaro
Engine: 305 TBI
what about combining the dual snorkel with the TPI type setup?...what do you think?
Old Apr 16, 2006 | 10:10 PM
Car: 1988 SC Camaro
Engine: 305 TBI
Old Apr 16, 2006 | 10:12 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Depends on what you drive and where you live. In cali they have road block smog checks believe it or not. Thank god Texas doesn't. If you have one in Cali and get stopped at a road block smog check, you are screwed and pay a hefty fine.
The open element sounds better for sure, but it sucks in way too much hot underhood air for my taste.
Old Apr 16, 2006 | 10:20 PM
dirtfarmer's Avatar
Engine: Lo3 305 TBI
Well the thing I was going for was to bring in cool air not heated air from under the hood.
When I come in from a drive and lift the hood I can feel the difference in the cal cover temp and the Strut tower temp.
It may be no big deal or big differance in HP. I just think cool air is a good thing.
Ron
Old Apr 16, 2006 | 10:33 PM
dirtfarmer's Avatar
Engine: Lo3 305 TBI
[QUOTE=Crusin' 1980's]I like that setup too! I never thought of it...I have a regular dual snorkel setup (that looks like Robot arms)...your idea is something to try perhaps...might get a little cramped in the engine bay with all the ducting however...hmm
Wow Crusin that looks like it will pull in the air.
Here is a shot with the top hose off.
This shows a little more info.
Ron
Attached Thumbnails Double Barrel cool air intake from GM parts-openview.jpg
Old Apr 17, 2006 | 02:53 PM
dirtfarmer's Avatar
Engine: Lo3 305 TBI
Well I got out Last night and looked at the problem.
I found the zip ties and looked at getting the #2 hose up and out of the way.
Using the ties I joined the hoses together then lifted them and secured them to the strut brace. It looks like there is enough space there for good air flow.
Check it out Let me know what you think.
This AM I got some shots so yall can see.
I know it is hard to see but the #2 hose is 3 in. from the valve cover at its closest point.
Ron
Attached Thumbnails Double Barrel cool air intake from GM parts-closeup-wties-back.jpg   Double Barrel cool air intake from GM parts-closeupwties.jpg   Double Barrel cool air intake from GM parts-wties.jpg
Old Apr 17, 2006 | 03:29 PM
dirtfarmer's Avatar
Engine: Lo3 305 TBI
Warning this may be
I had one of the air scoops left over so.....It hit me to use it to feed more air to the lower cool air intake.
My thought was if I could pull air from under the car and deliver it to the #2 intake IE the space behind the head light it couldn't hurt.
Well It fit so easy and there was a ready made mount bolt from the ground clearance mount there. I just put it on.
If some how it builds a higher air pressure there (behind the lights) at "cruse" speed. I should get better air flow "ram air".
See I told you to look out for stuff flowing down hill.
Here are the shots. The thing is hard to see behind the light mount ...and harder to photograph.
It is easy to see under the car the scoop is going to get some air.
Check it out.....
Ron
Attached Thumbnails Double Barrel cool air intake from GM parts-behindthelight.jpg   Double Barrel cool air intake from GM parts-underlightintake.jpg   Double Barrel cool air intake from GM parts-closeuptopscoop-.jpg
Old Apr 17, 2006 | 03:33 PM
Car: 1988 SC Camaro
Engine: 305 TBI
hey Dirtfarmer, I looked at my car today to see if i would be able to do what you did, but my evap canister for the gas is right in the way...what did you do with yours?...maybe I'll re-locate mine eventually and try what you did...but the canister seems to be right in the way of instralling another air duct right below the stock one...
Old Apr 17, 2006 | 03:41 PM
dirtfarmer's Avatar
Engine: Lo3 305 TBI
Oh you are right I did move the canister over.
The thing has a funny mount....when you take the mount bolts out a tension held sort of hook for the bottom of the canister falls out. I just moved the canister over (toward the fender) and remounted it using self tapping screws.
That opens up the space for the inverted scoop.
Old Apr 17, 2006 | 04:10 PM
Car: 1988 SC Camaro
Engine: 305 TBI
Good Idea...I think I'll check mine out soon and see if i can move it out of the way...i might even get creative and mount in under the car, towards the front bumper...I'll see if it can be done without showing from underneath...it would be nice if i could re-locate it completely out of view
Old Apr 17, 2006 | 11:00 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I like the OE much better because it dresses up the engine bay a little bit and the sound it makes is righteous.
With the power bulge hood I'm getting soon, it should have no problems getting all the cool air it needs. Plus, I've never seen a randon road side inspection for modified cars. I suppose the cops in the Bay Area have worse things to think about.
Very cool ideas though. How did you cut the hole in the side of the air lid?
Old Apr 18, 2006 | 09:36 AM
dirtfarmer's Avatar
Engine: Lo3 305 TBI
Cadillac,
That is a good looking rig. I think you're OE it is clean easy and looks great.
I used an air cut off wheel to cut the inside of the air lid. Then used an air grinder to "finish" the hole. The metal is thin and easy to cut. The weld there is tricky. I just spot welded several spots. I was afraid of burning a hole in it.
I plan to seal it with black high heat silicone.
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
