Old Skewl TBI camshaft
Old Apr 24, 2006 | 12:01 PM
michal_larson's Avatar
I currently have a 1988 TBI 305 camaro automatic and the car is stock with the only mod of a 1969 DZ 30/30 Duntov solid lifter camshaft. The car ran a 17.3 stock and the camshaft is the only mod done. Any one ever used a cam this size in a TBI car? Im thinking its in the low 15's now, but dreaming of 14's.
Old Apr 24, 2006 | 01:25 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Well a 17.3 run means something is not right. A properly tuned lo3 should run anywhere from 15.7- 16.5. Also you should check out the stickies before jumping into a cam swap without reasonable planning.
Our cams are hydralic roller not solid mechanical. So the cam won't slap in. Also you are dreaming way too much, because with the cam swap you suggested you are doubtful to get the car to run.
EDIT:
After getting the specs on the dz 30/30 cam, that would be one of the worst choices with a stock tbi car.
Cam Technical Notes: Basic rpm range is 4000 - 6800; and compression ratio is 11.0 - 12.5. The duration at .050 lift (intake/exhaust) is 254/254 degrees, and the valve lift is .485"/.485". Lobe centerline is 114. T
Old Apr 24, 2006 | 03:09 PM
The car seems to run ok, MPH went from 79 to 90, i wasnt aware that you couldnt change to solid lifter
Old Apr 24, 2006 | 03:21 PM
man i spent long hours looking at cams....please dont tell me i didnt go big enuff, the cam i was going to get was a 263/273 duration cam @ .512 lift
Old Apr 24, 2006 | 03:24 PM
If this is a stock 305 TBI car, that would be a grossly inappropriate cam.
It will be all but impossible to get it to idle right.
It will have ABSOLUTELY ZERO leave: you'll literally be able get out and push the car harder than it will launch.
If the car ran 17s stock, it will probably go 20 to 21 with that cam as its only mod.
Yes I mean that. I've had that cam before.
Old Apr 24, 2006 | 03:25 PM
SchwarzCamaroRS's Avatar
no, its the RPM range thats a lil off to TBI... 4000-6800 is past the powerband. TBI makes it earlier 3000-4500. You also have to be careful with a high lift cam because if youre still using stock heads, .480" lift is coming REAL close to hitting the valve guides
Old Apr 24, 2006 | 03:26 PM
you mean this cam wont run?
Old Apr 24, 2006 | 03:28 PM
in 88, i think it still was solid lifter wasn't it. They didnt switch to roller motors till 90-91 IIRC
and no, it will run, probably will sound really cool too, IF you get it to idle right, but you need better heads and EXTENSIVE tuning to get that setup to perform like you hope. More fuel will be needed too to keep it from running lean with that much lift too.
Last edited by SchwarzCamaroRS; Apr 24, 2006 at 03:30 PM. Reason: Automerged Doublepost
Old Apr 24, 2006 | 03:33 PM
There hasn't been a Camaro motor that came with solid lifters since about 71.
They changed from flat-tappet hydraulic to hydraulic roller lifters in 87 in these cars.
Yes you can put a solid-lifter flat-tappet cam in a roller block. That isn't an issue.
No the cam will not run worth a crap in that setup. It is about as completely wrong a cam, a total mismatch, as you can get. In fact it probably IS the single worst GM cam you could use.
The motor will "work", but the car will not "run". It will barely crawl. It will SOUND terrific; but it will be one of those "all show no go" wonders, like the all-chrome L48s with chrome 6-71 blowers and 2 chrome carbs on them that you see at street rod shows, that don't have enough power to drive up onto their trailers.
i has "187" swirl heads and the exhaust tone is alot louder IT RAWKS
Old Apr 24, 2006 | 03:35 PM
Time slips please
Old Apr 24, 2006 | 03:36 PM
i wonder y its faster now. is there someway i could upload a wav file of the thing?
Old Apr 24, 2006 | 03:46 PM
faster
wav file
2 different things....
Just like "looks better" doesn't always equal "faster".
Incidentally, I believe you when you say it sounds good; I told you it would.
I know, because I've had that cam before. I'm guessing, about the time your daddy was a gleam in your grand-daddy's eye.
Time slips please. Without those, it's all spank-off.
Old Apr 24, 2006 | 03:48 PM
i marked off 1320 feet on a backroad and tune to MPH
Time slips please
Official ones
Old Apr 24, 2006 | 03:53 PM
Im trying to "tune" around the slow take off.
Old Apr 24, 2006 | 03:55 PM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
Is this thread some sort of a sick joke?
It's not April 1st again is it?
Old Apr 24, 2006 | 03:56 PM
no i actually installed this cam, and it is faster now
there is alot more exhaust flow at idle now
Last edited by michal_larson; Apr 24, 2006 at 03:57 PM. Reason: Automerged Doublepost
Old Apr 24, 2006 | 04:03 PM
it is faster now
I'll believe it WHEN I SEE A TIME SLIP!!!
Until then, ..... well, let's just say, I'll believe it when I see a time slip. Make sure it shows your 60'.
Old Apr 24, 2006 | 04:04 PM
i race at gateway international raceway
Old Apr 24, 2006 | 04:10 PM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Good. Then you'll have plenty of official timeslips to post up.
Old Apr 24, 2006 | 05:29 PM
i have a audio file, its really a good sounding camshaft, i put it in gear and let the tires spin on concrete but i have no idea how to post it. it idles ok @ 900 rpms how can i attach my audio file? if you hear this file, it will let you know how much i know about tunning. but anyway, i have it on putfile http://media.putfile.com/My-Duntov-3030-cammed-305 also, this isnt a joke, as you all know that tunning a tbi car with that size of camshaft takes some figuring out, so listen and tell me what you think
Old Apr 24, 2006 | 05:59 PM
also, i have a buddy with a g-tech, i guess we could video tape running with the g-tech, i dont get the whole timeslip[ thing, i have timeslips from another car running mid 14's, how whould you know that that was the car i have now?
Old Apr 24, 2006 | 06:06 PM
i aint lookin to fight.....and i aint out to change the world.....just like large camshafts is all
Old Apr 24, 2006 | 07:35 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
We call BS on this because a cam with 210 deg of duration will some times causes stalling and ruff idling (not in a good way). For you to run a cam with a full 44 deg more duration and say it runs fine is darn near impossible. Heck my 350 with a 218 deg cam wouldn't even start let alone idle. That cam is so far mismatched to the rest of your motor that you are most certainly going to be much slower. Sure it'll feel fast because it will pretty much fall on it's face till 4 grand and then start pulling hard just to fall on it's face again at 5 grand when the intake, heads, and exhaust all max out simultaneously. Of course this is all assuming that it would even start and run....which I'm pretty sure it won't. There are also about 10 other tuning related reasons this won't work too, but I won't go into that unless your actually tuning this combo....which I don't think you are.
Hopefully your just confused on the size cam you put in, are you sure you're looking at the .050 duration numbers and not the advertised duration numbers?
Old Apr 24, 2006 | 07:46 PM
nope the specs are as they appear, go ahead and listen to my audio file, it is amazing what i have done Putfile - My Duntov 3030 cammed 305 i did tell people i was putting that cam in and with tunning cars for over 20 years, i can do it with ease i can show you my bin file for ecu i use if ud like
Old Apr 24, 2006 | 07:56 PM
oh yeah, by the way, the camshaft @ .050" is 83 degrees larger than the stock one i took out its all good, just have ta know how to tune to a large duration camshaft
Old Apr 24, 2006 | 07:58 PM
BMmonteSS's Avatar
Car: 84' Monte
Alrighty then Michal, first of all that cam has no lope whats so ever. It sounds like it idles perfectly smooth. A cam that big won't idle at less than 1000 RPM and even at that is gonna have a nasty pro-stock like lope. Your sounds like a stock car with glasspacks.
What you have done is NOT AMAZING, well I take that back it is amazing how bad of an idea it is. Every single part of your engine is designed for an idle to 4500 RPM power band, that cam is designed for a 4000 rpm to 7000 RPM power band. This is a perfect example of mismatched combo if I've ever seen one.
By tuning, I assume you don't mean you burn your own chips right? That cam is so big that you would have to be very sharp, and know a heck of a lot more than 99% of the members on this board. It would also mean you would have had to have been on this board learning how to tune your chip...since this is the only place to learn that from. Judging by your post count, and the way you word your post I highly doubt that you even know where your computer is located let alone how to tune a GM computer to run well with a cam that big.
So are you sure you have a TBI system on your car and not a carburetor? TBI = 2 injectors over 2 throttle bores.
Old Apr 24, 2006 | 08:06 PM
BMmonteSS's Avatar
Car: 84' Monte
178-254=76
So do share with us your vast tuning knowledge....is it hypertech, or tbichips.com that you got your chip from?
By the way check out the top of this board if you want to see an example of how to properly tune a TBI motor (come in for a free tune) not that I've actually tuned a tbi vehicle or anything.
Old Apr 24, 2006 | 08:09 PM
are you saying that im lying?
i create my own bin files, its far from stock
178-254=-76
y are you scared of large cams? have you ever even tried one?
Last edited by michal_larson; Apr 24, 2006 at 08:14 PM. Reason: Automerged Doublepost
Old Apr 24, 2006 | 08:18 PM
BMmonteSS's Avatar
Car: 84' Monte
No I'm saying that I haven't seen you around here or the DIY prom board, and the biggest cam I've ever seen tuned in any GM OBD1 base vehicle was full 10 deg shorter duration.....and the person who tuned that is a very sharp indivdual that has contributed alot to the boards.
So what map value does this cam idle at? What parts of the tune did you have the most problem with? What kind of burner do you use.
I don't mean to sound rude, for all I know you could be a GM calibrations engineer with bad grammer.
P.S. My 218 226 cam idles great, and I don't need turn my motor any faster than 6000 rpm so I haven't used a bigger cam than that, even if I did I wouldn't use a cam that uses 30 year old technology.
Old Apr 24, 2006 | 08:23 PM
i dunno, all i can do is tell you what ive done. i know my car and how to tune it and it DID take me like 400 burns to get it where it is now. the car does not fall on its face, the transmission i calibrated to shift @ 6000 rpms wot. the car would not run or barley started with stock tunning
i use tunerpro, do you use this to?
Last edited by michal_larson; Apr 24, 2006 at 08:25 PM. Reason: Automerged Doublepost
Old Apr 24, 2006 | 08:32 PM
BMmonteSS's Avatar
Car: 84' Monte
Thats great, I stand corrected. Please share how you did it and enlighten the rest of us as to how you over came a lot of the inherent problems with TBI.
You could start by letting us know what your complete combo is. Just droping in with less than 20 post to your name and saying hey ya'll I put the biggest nasties cam I could find in my stock LO3 and it runs GREAT, tends to lift a few eyebrows around here. Then when people start asking questions you don't give any more info or even track times when you say you went to the track it even further discredits you. I'll give you the benefit of a doubt and say this was all just a big miscommunication, now BRING THE TECH. Let us know your whole combo, what you had to do to get it to idle. How you delt with the massive overlap of that cam and the stock code. I'll take any info you'll give me.
Old Apr 24, 2006 | 08:36 PM
im sorry, all my engines had wild camshafts, but the duntov "30/30" camshaft is that i use, this is the only car ive owned that ive burned chips for, most others were carb and TPI stuff, it is tricky, but its not rocket science either, if you build a motor and use my chip, it may not run, like i said, i know my car and what it likes.
Old Apr 24, 2006 | 09:14 PM
BMmonteSS's Avatar
Car: 84' Monte
Don't be sorry, this board is to share our knowledge and to help each other out. We just want more info to better understand what you did. Some guys wanted you to better quantify your performance gains and all you offered was a sound clip of how kewl it sounded and how much it rowks. We can't get much from that....do see where I'm coming from?
So I'm interested in what you had to do to get it to idle well. I also noticed you just got your ECU file on the 14th, so you've been busy burning 40 chips per day since then so it should all be pretty fresh in your mind. So here we go...
1. Did you go open loop at idle?
2. Are you running synch or asynch at idle?
3. How are you dealing with the wide dynamic range of PW's that cam will require? (too small of PW at idle, too long at high rpm)
4. What size injectors and what pressure are you running?
Also that cam would render the stock O2 pretty much useless so how did you go about tuning your fuel curves?
I hope we agree that the cam you choose is a horrible mismatch to the rest of your combo. We've all done something for the heck of it, and it sounds like this was your plan all along since you're more concerned with the sound than the performance of your motor.
So please Michal, bring the tech. Take the time to let us know how you did the unspeakable of putting that raunchy cam in your stock LO3. I've got no problem with what you've done, just a problem with how you've presented it and how you've responded to some basic questions.
Old Apr 24, 2006 | 09:19 PM
Putfile - Michals 305 duntov 153 g tech run for thirdgenorg
my car idles open loop
it does not idle async
Last edited by michal_larson; Apr 24, 2006 at 09:20 PM. Reason: Automerged Doublepost
Old Apr 24, 2006 | 09:24 PM
my injectors are from a 4.3L tbi truck
wait a minute, thats funny, i really not sure if it idles async or sync, guess ill have to look into it i know it goes into async mode when i let off the pedal at round 2000 rpms to 1000 rpms then resumes
Last edited by michal_larson; Apr 24, 2006 at 09:26 PM. Reason: Automerged Doublepost
Old Apr 24, 2006 | 09:34 PM
BMmonteSS's Avatar
Car: 84' Monte
I'll let you organize your thoughts and make one comprehensive post as to what all you've done. Just let us know what your goals were with this cam. Also what fuel pressure were you running with the 4.3 injectors and is there a reason for the 4.3 injectors?
Old Apr 24, 2006 | 09:56 PM
im at 14 psi
Edit Log for expirement.Bin created by TunerPro.
04/04/2006 14:41:40 Table: Delta Map AcelPmp uSec changed.
04/04/2006 14:42:27 Table: Accel Pump vs. Coolant changed.
04/04/2006 17:39:01 Table: PE AFR changed.
04/04/2006 17:39:34 Table: Accel Pump vs. Coolant changed.
04/04/2006 17:39:57 Table: Delta Map AcelPmp uSec changed.
04/04/2006 17:40:05 Table: Delta TPS AcelPmp uSec changed.
04/04/2006 17:40:53 Table: PE AFR changed.
04/04/2006 17:41:07 Table: PE AFR changed.
04/04/2006 17:41:41 Table: VE as % (FL1) changed.
04/04/2006 18:23:41 Table: PE AFR changed.
04/04/2006 18:26:19 Constant: Max RPM for Spark Slope(strts 3600) changed from 0.00 RPM (0x00) to 4600.00 RPM (0xB8).
04/04/2006 18:26:44 Constant: Spark Slope-Deg/1K Rpm changed from 0.00 Deg (0x00) to 7.03 Deg (0x40).
04/04/2006 18:27:06 Constant: Max RPM for Spark Slope(strts 3600) changed from 4600.00 RPM (0xB8) to 4600.00 RPM (0xB8).
04/04/2006 18:46:53 Constant: Stoich AFR changed from 14.80 (0x94) to 14.70 (0x93).
04/04/2006 18:48:35 Table: VE as % (FL1) changed.
04/04/2006 18:48:42 Table: VE as % (FL1) changed.
04/04/2006 18:48:44 Constant: BPW Const for EGR off changed from 175.00 (0xAF) to 175.00 (0xAF).
04/04/2006 18:49:05 Table: PE AFR changed.
04/04/2006 18:49:38 Table: VE as % (FL1) changed.
04/04/2006 18:49:40 Table: VE as % (FL2) changed.
04/04/2006 18:50:00 Table: PE enable at VDC of TPS changed.
04/04/2006 18:50:37 Table: Accel Pump vs. Coolant changed.
04/04/2006 19:26:08 Table: VE as % (FL1) changed.
04/04/2006 20:03:13 Table: Accel Pump vs. Coolant changed.
04/04/2006 20:03:20 Constant: Max RPM for Spark Slope(strts 3600) changed from 4600.00 RPM (0xB8) to 0.00 RPM (0x00).
04/04/2006 20:03:23 Constant: Spark Slope-Deg/1K Rpm changed from 7.03 Deg (0x40) to 0.00 Deg (0x00).
04/04/2006 20:03:58 Table: PE AFR changed.
04/04/2006 20:04:15 Constant: BPW Const for EGR off changed from 175.00 (0xAF) to 183.00 (0xB7).
04/04/2006 20:04:35 Constant: Min BLM changed from 117.00 (0x75) to 100.00 (0x64).
04/04/2006 20:04:37 Constant: Max BLM changed from 135.00 (0x87) to 135.00 (0x87).
04/04/2006 20:04:46 Constant: BPW Const for EGR off changed from 183.00 (0xB7) to 191.00 (0xBF).
04/04/2006 20:06:29 Table: Main Spark Advance changed.
04/04/2006 20:07:15 Table: Main Spark Advance changed.
04/04/2006 20:08:06 Table: Desired ClsdLp Idle Speed changed.
04/04/2006 20:08:36 Table: PE enable at VDC of TPS changed.
04/04/2006 20:08:50 Table: PE AFR changed.
04/04/2006 20:12:55 Table: Main Spark Advance changed.
04/04/2006 20:14:38 Table: VE as % (FL1) changed.
04/04/2006 20:14:53 Table: VE as % (FL1) changed.
04/04/2006 20:15:13 Table: VE as % (FL2) changed.
04/04/2006 20:15:51 Table: VE as % (FL2) changed.
04/04/2006 20:16:36 Table: Delta Map AcelPmp uSec changed.
04/04/2006 20:17:21 Table: Delta TPS AcelPmp uSec changed.
04/04/2006 20:17:22 Table: Delta Map AcelPmp uSec changed.
04/04/2006 20:18:27 Table: Prop Gain Flow Factor vs. Air Flow changed.
04/04/2006 20:19:58 Table: PE enable at VDC of TPS changed.
04/04/2006 20:21:34 Constant: Initial Spark Advance changed from 17.23 Deg (0x31) to 14.06 Deg (0x28).
04/04/2006 20:21:38 Constant: Initial Spark Advance changed from 14.06 Deg (0x28) to 14.06 Deg (0x28).
04/04/2006 21:40:39 Table: VE as % (FL1) changed.
04/04/2006 21:43:54 Table: VE as % (FL1) changed.
04/04/2006 21:52:37 Table: VE as % (FL1) changed.
04/05/2006 12:18:22 Table: VE as % (FL1) changed.
04/05/2006 12:18:39 Table: Main Spark Advance changed.
04/05/2006 12:19:56 Table: Accel Pump vs. Coolant changed.
04/05/2006 12:20:14 Table: A/F during Cranking changed.
04/05/2006 12:20:28 Table: Main Spark Advance changed.
04/05/2006 12:21:20 Table: VE as % (FL2) changed.
04/05/2006 12:21:58 Table: VE as % (FL1) changed.
04/05/2006 14:21:53 Constant: Max BLM changed from 135.00 (0x87) to 138.00 (0x8A).
04/05/2006 14:22:02 Constant: Min BLM changed from 100.00 (0x64) to 90.00 (0x5A).
04/05/2006 14:22:45 Table: PE enable at VDC of TPS changed.
04/05/2006 19:51:44 Table: VE as % (FL1) changed.
04/05/2006 19:52:28 Table: VE as % (FL1) changed.
04/05/2006 19:53:16 Constant: RPM Thres for PE changed from 0.00 (0x00) to 2500.00 (0x64).
04/05/2006 19:54:28 Constant: Injector Bias (added) changed from 396.50 Usec (0x001A) to 457.50 Usec (0x001E).
04/05/2006 19:54:53 Constant: Min Asynch BPW changed from 686.25 Usec (0x002D) to 503.25 Usec (0x0021).
04/05/2006 19:54:56 Constant: Max Asynch BPW changed from 15600.75 Usec (0x03FF) to 11986.50 Usec (0x0312).
04/05/2006 19:59:07 Constant: Maximum Spark Allowed changed from 36.91 Deg (0x69) to 41.84 Deg (0x77).
04/05/2006 19:59:31 Table: Main Spark Advance changed.
04/05/2006 20:01:02 Table: PE AFR changed.
04/05/2006 20:01:04 Table: PE enable at VDC of TPS changed.
04/05/2006 20:01:40 Table: Accel Pump vs. Coolant changed.
04/05/2006 20:01:46 Table: PE Spark in Degrees changed.
04/05/2006 20:04:49 Constant: RPM Thres for PE changed from 2500.00 (0x64) to 4000.00 (0xA0).
04/05/2006 20:04:50 Table: PE Spark in Degrees changed.
04/05/2006 20:06:00 Table: VE as % (FL2) changed.
04/06/2006 01:21:04 Table: VE as % (FL1) changed.
04/06/2006 01:21:47 Table: VE as % (FL2) changed.
04/06/2006 16:24:13 Table: VE as % (FL2) changed.
04/06/2006 16:25:04 Table: VE as % (FL1) changed.
04/06/2006 16:25:30 Table: VE as % (FL1) changed.
04/06/2006 16:26:18 Table: VE as % (FL1) changed.
04/06/2006 16:26:32 Table: VE as % (FL1) changed.
04/06/2006 16:27:42 Table: VE as % (FL1) changed.
04/06/2006 16:27:56 Table: VE as % (FL2) changed.
04/06/2006 16:27:57 Table: Voltage Comp vs. Battery changed.
04/06/2006 16:27:58 Table: VE as % (FL1) changed.
04/06/2006 16:28:26 Table: Delta Map AcelPmp uSec changed.
04/06/2006 16:28:51 Constant: Initial Spark Advance changed from 14.06 Deg (0x28) to 16.87 Deg (0x30).
04/06/2006 16:34:46 Table: VE as % (FL2) changed.
04/06/2006 16:35:14 Table: PE AFR changed.
04/06/2006 16:35:41 Table: IAC Position vs Temp changed.
04/06/2006 16:35:44 Table: Stall saver steps Added Vs. MAP changed.
04/06/2006 16:35:44 Table: IAC vs. Baro at Reset changed.
04/06/2006 16:42:51 Constant: Initial Spark Advance changed from 16.87 Deg (0x30) to 14.41 Deg (0x29).
04/06/2006 16:44:43 Table: VE as % (FL1) changed.
04/06/2006 16:45:13 Table: VE as % (FL2) changed.
04/06/2006 16:45:36 Table: VE as % (FL2) changed.
04/06/2006 16:45:51 Table: VE as % (FL2) changed.
04/06/2006 16:45:52 Table: VE as % (FL1) changed.
04/07/2006 06:12:08 Table: VE as % (FL1) changed.
04/07/2006 06:12:14 Table: VE as % (FL1) changed.
04/07/2006 06:17:39 Table: Startup Spk Added changed.
04/07/2006 06:19:59 Table: Main Spark Advance changed.
04/07/2006 06:20:57 Table: PE Spark in Degrees changed.
04/07/2006 06:22:28 Table: Main Spark Advance changed.
04/07/2006 06:27:22 Table: Main Spark Advance changed.
04/07/2006 06:29:25 Constant: BPW Const for EGR off changed from 191.00 (0xBF) to 176.00 (0xB0).
04/07/2006 06:29:58 Constant: Delay PE Below RPM changed from 2025.00 (0x51) to 4000.00 (0xA0).
04/07/2006 06:31:42 Constant: PE not Delayed is TPS% GT changed from 0.00 (0x00) to 69.92 (0xB3).
04/07/2006 06:33:33 Table: Main Spark Advance changed.
04/07/2006 06:33:42 Table: PE Spark in Degrees changed.
04/07/2006 06:34:30 Table: Main Spark Advance changed.
04/07/2006 06:37:34 Table: PE Spark in Degrees changed.
04/07/2006 06:41:31 Table: VE as % (FL1) changed.
04/07/2006 06:42:07 Table: VE as % (FL2) changed.
04/07/2006 06:42:41 Table: VE as % (FL1) changed.
04/07/2006 06:44:09 Table: VE as % (FL1) changed.
04/07/2006 07:02:06 Table: PE Spark in Degrees changed.
04/07/2006 07:02:16 Table: PE Spark in Degrees changed.
04/07/2006 07:04:12 Table: Main Spark Advance changed.
04/07/2006 07:06:34 Table: PE Spark in Degrees changed.
04/07/2006 07:06:35 Table: Main Spark Advance changed.
04/07/2006 07:08:22 Table: PE Spark in Degrees changed.
04/07/2006 07:09:07 Table: PE AFR changed.
04/07/2006 07:09:23 Table: PE AFR changed.
04/07/2006 07:10:24 Table: Async Fuel Mult vs. RPM changed.
04/07/2006 07:11:45 Table: Cold AFR vs. MAP (Added to AFR vs. Temp) changed.
04/07/2006 07:12:57 Table: HiWay Spark Added changed.
04/07/2006 07:13:26 Table: Delta Map AcelPmp uSec changed.
04/07/2006 07:13:38 Table: Delta TPS AcelPmp uSec changed.
04/07/2006 07:14:03 Table: Delta TPS AcelPmp uSec changed.
04/07/2006 07:14:23 Table: TPS Filter Coef vs. Coolant changed.
04/07/2006 07:14:36 Table: MAP Filter Coef vs. Coolant changed.
04/07/2006 07:17:31 Table: Startup Spk Added changed.
04/07/2006 08:01:04 Constant: Initial Spark Advance changed from 14.41 Deg (0x29) to 14.06 Deg (0x28).
04/07/2006 08:11:36 Table: Main Spark Advance changed.
04/07/2006 08:18:20 Table: PE Spark in Degrees changed.
04/07/2006 08:19:32 Table: PE Spark in Degrees changed.
04/07/2006 08:22:16 Table: VE as % (FL1) changed.
04/07/2006 08:23:58 Table: VE as % (FL1) changed.
04/07/2006 08:24:00 Table: PE Spark in Degrees changed.
04/07/2006 08:24:06 Table: Main Spark Advance changed.
04/07/2006 08:28:03 Table: PE Spark in Degrees changed.
04/07/2006 08:33:24 Table: Main Spark Advance changed.
04/07/2006 08:33:43 Table: Startup Spk Added changed.
04/07/2006 12:16:31 Table: Main Spark Advance changed.
04/07/2006 14:20:30 Table: Main Spark Advance changed.
04/07/2006 14:24:51 Table: VE as % (FL1) changed.
04/07/2006 14:25:50 Table: VE as % (FL1) changed.
04/07/2006 14:25:51 Table: Main Spark Advance changed.
04/07/2006 14:27:39 Table: Main Spark Advance changed.
04/07/2006 14:28:44 Table: A/F during Cranking changed.
04/07/2006 14:29:20 Constant: Min O/L AFR at Idle changed from 15.00 (0x96) to 15.50 (0x9B).
04/07/2006 15:42:31 Constant: BPW Const for EGR off changed from 176.00 (0xB0) to 158.00 (0x9E).
04/07/2006 15:44:29 Table: Main Spark Advance changed.
04/07/2006 15:45:24 Table: VE as % (FL1) changed.
04/07/2006 15:46:08 Constant: Exit Stall Saver RPM changed from 512.50 (0x29) to 500.00 (0x28).
04/07/2006 15:46:19 Constant: Stall Saver RPM changed from 412.50 (0x21) to 475.00 (0x26).
04/07/2006 15:46:29 Constant: Stall Saver RPM changed from 475.00 (0x26) to 437.50 (0x23).
04/07/2006 15:46:30 Constant: Exit Stall Saver RPM changed from 500.00 (0x28) to 500.00 (0x28).
04/07/2006 15:46:38 Constant: %TPS for Closed Throttle changed from 2.73 (0x07) to 1.17 (0x03).
04/07/2006 15:48:09 Constant: BPW Const for EGR off changed from 158.00 (0x9E) to 169.00 (0xA9).
04/07/2006 15:48:11 Table: OpLp A/F vs Temp changed.
04/07/2006 15:48:48 Table: Cold AFR vs. MAP (Added to AFR vs. Temp) changed.
04/07/2006 15:49:19 Table: PE AFR changed.
04/07/2006 15:49:59 Table: Delta TPS AcelPmp uSec changed.
04/07/2006 15:50:20 Table: Delta Map AcelPmp uSec changed.
04/07/2006 15:50:45 Table: Delta TPS AcelPmp uSec changed.
04/07/2006 15:51:12 Table: Accel Pump vs. Coolant changed.
04/07/2006 15:52:19 Table: Delta Map AcelPmp uSec changed.
04/07/2006 15:52:20 Table: Delta TPS AcelPmp uSec changed.
04/07/2006 15:59:09 Table: Main Spark Advance changed.
04/07/2006 17:22:08 Table: Main Spark Advance changed.
04/07/2006 17:23:36 Table: HiWay Spark Added changed.
04/08/2006 00:29:10 Table: Delta TPS AcelPmp uSec changed.
04/08/2006 00:29:24 Table: Delta Map AcelPmp uSec changed.
04/08/2006 00:29:49 Table: HiWay Spark Added changed.
04/08/2006 00:31:17 Table: Main Spark Advance changed.
04/08/2006 00:31:55 Table: Main Spark Advance changed.
04/08/2006 00:34:06 Table: VE as % (FL1) changed.
04/08/2006 00:34:40 Table: OpLp A/F vs Temp changed.
04/08/2006 15:05:19 Table: Delta TPS AcelPmp uSec changed.
04/08/2006 15:05:32 Table: Delta Map AcelPmp uSec changed.
04/08/2006 15:05:49 Table: Accel Pump vs. Coolant changed.
04/08/2006 15:06:21 Table: Main Spark Advance changed.
04/08/2006 15:12:35 Table: Main Spark Advance changed.
04/08/2006 15:13:36 Table: Accel Pump vs. Coolant changed.
04/08/2006 15:13:37 Table: VE as % (FL1) changed.
04/08/2006 15:18:44 Table: Delta Map AcelPmp uSec changed.
04/08/2006 15:18:45 Table: Delta TPS AcelPmp uSec changed.
04/08/2006 17:59:01 Table: Main Spark Advance changed.
04/08/2006 18:07:20 Constant: Maximum Spark Allowed changed from 41.84 Deg (0x77) to 15.12 Deg (0x2B).
04/08/2006 18:07:22 Constant: Spark Bias - Warm changed from 0.00 Deg (0x00) to 0.00 Deg (0x00).
04/08/2006 18:08:12 Table: Main Spark Advance changed.
04/08/2006 18:08:30 Constant: Maximum Spark Allowed changed from 15.12 Deg (0x2B) to 15.12 Deg (0x2B).
04/08/2006 18:08:51 Constant: Initial Spark Advance changed from 14.06 Deg (0x28) to 23.20 Deg (0x42).
04/08/2006 18:09:54 Constant: Initial Spark Advance changed from 23.20 Deg (0x42) to 22.15 Deg (0x3F).
04/08/2006 18:10:08 Constant: Initial Spark Advance changed from 22.15 Deg (0x3F) to 20.74 Deg (0x3B).
04/08/2006 18:11:55 Table: Main Spark Advance changed.
04/08/2006 18:16:03 Table: Main Spark Advance changed.
04/08/2006 18:16:25 Table: VE as % (FL1) changed.
04/08/2006 18:16:39 Table: VE as % (FL2) changed.
04/08/2006 18:16:58 Table: VE as % (FL2) changed.
04/09/2006 22:19:49 Table: VE as % (FL1) changed.
04/10/2006 16:16:00 Table: VE as % (FL1) changed.
04/10/2006 16:16:32 Table: IAC Position vs Temp changed.
04/10/2006 16:18:43 Table: Main Spark Advance changed.
04/10/2006 16:20:19 Table: Main Spark Advance changed.
04/10/2006 19:42:29 Table: VE as % (FL2) changed.
04/10/2006 20:19:43 Table: VE as % (FL2) changed.
04/10/2006 20:19:47 Table: EGR VE Comp Table changed.
Last edited by michal_larson; Apr 24, 2006 at 10:00 PM. Reason: Automerged Doublepost
Old Apr 24, 2006 | 10:01 PM
that is from the last couple of days
Welcome to my homepage!
Last edited by michal_larson; Apr 24, 2006 at 10:04 PM. Reason: Automerged Doublepost
Old Apr 24, 2006 | 10:05 PM
BMmonteSS's Avatar
Car: 84' Monte
That doesn't really tell me much, just a well put together paragraph of what needed to be tweaked and tuned at idle would be nice. Also how did you start tuning if you didn't even have an ECU file untill the 14th?
Old Apr 24, 2006 | 10:07 PM
  #42
67.19 71.88 75.78 78.91 81.25 83.20 84.38 85.55
64.45 69.14 73.05 76.17 79.30 80.86 82.42 83.20
61.72 67.58 69.92 74.61 77.73 79.30 80.08 80.47
51.56 59.38 67.97 72.27 75.78 77.34 78.91 78.91
40.23 51.56 62.11 70.31 73.44 75.39 76.95 76.17
34.38 46.88 57.42 67.58 72.27 74.61 75.78 74.61
30.47 41.02 52.73 65.23 69.53 71.88 72.27 71.09
26.56 37.11 49.22 60.55 64.84 67.97 69.14 67.58
18.36 20.31 24.22 28.13 32.42 36.33 37.89 39.84
my VE fuel map
the date on my computer is off, y dont you think this camshaft wont idle?
it was rough idling my cabed cars but fuel injection is easy
Last edited by michal_larson; Apr 24, 2006 at 10:09 PM. Reason: Automerged Doublepost
Old Apr 24, 2006 | 10:13 PM
  #43
you guys should already know how to make a bin file for a radical camshaft
hang on guys, i just made another burn and im going out to da car to put it in brb
Last edited by michal_larson; Apr 24, 2006 at 10:16 PM. Reason: Automerged Doublepost
Old Apr 24, 2006 | 10:46 PM
  #44
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
This thread's pretty entertaining/funny. I'm just waiting now while you make another burn. Was that video a joke too? hah
Old Apr 25, 2006 | 10:47 AM
  #45
Car: 91 Camaro RS
Can you post us your latest bin file? What is your complete list of mods? Just the cam and the injectors or is there more?
Old Apr 25, 2006 | 11:34 AM
  #46
the only other engine mod is an open air cleaner, the injectors flow about the same as the stock one, getting the engine to idle was easy, still working on part throttle. i thought there was a guy with an IROC running 11's(traxton) or something, he give one idea that really works well with a large duration camshaft. and im not just going to "give" anyone my bin file, i worked hard on it and its all my own ideas.
are you close to wentzville missouri?
Last edited by michal_larson; Apr 25, 2006 at 11:36 AM. Reason: Automerged Doublepost
Old Apr 25, 2006 | 11:42 AM
  #47
i will tell you this, my spark and fuel resemble the "ARAP" vette bin i used ideas from that bin
Old Apr 25, 2006 | 11:58 AM
  #48
BMmonteSS's Avatar
Car: 84' Monte
There isn't a certain "trick" or magic button to push to make a big cam idle. I most certianly know "how" to make a big cam idle.....doing it in practice is why I doubt you have done it so easily. But spare me the "I'm not giving me secrets away" BS, you haven't done anything earth shatering in that bin. Actually by looking at that edit log you posted it looks like you fiddled around with alot of stuff that should have been set and forgotten about. See the section where you fiddled with the initial spark advance. This constant is nothing more than the amount of spark advance that you mechanically have the distributor set to.
You're spending alot of time proving that you can walk the walk (idling video and useless edit log) and you're not spending a whole lot of time talking the talk.......which makes me doubt the walk, or skip or leap frog or whatever it is your doing in this thread.
If this post was ment as simply a place to brag about your big ole cam, with no intent of enlighting the rest of us as to why and how you did it then fine move along and we'll let this waste of bandwidth fade into the distance. If not then start providing some TECH. Let us know how you managed to move the power band up 2000 rpm and make around 100 more HP than you were making before (10 hp per MPH rule of thumb) and not increase the injector size.....even though in completely stock form LO3's are borderline static. Also please do explain how you were able to work around the jumpy eratic MAP readings....also what MAP value do you idle at???
Edit: Thats great I see you some how took the MAF tables from a mass air ecm and converted them to a VE table for your speed density TBI setup....... Didn't know that was possible. You also know that the timing table for the ARAP chip is very agressive, too agressive for an iron head, let alone the swirl port heads on your engine, which like 28 deg of total timing.
Quick go back to searching and find some more answers to my questions.
Old Apr 25, 2006 | 12:08 PM
  #49
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
BTW, the Duntov 30/30 is not too much hotter than the L82 cam that I had in my old 312. Granted everything on mine was setup for high RPM running. Holley Projection intake, 454 TBI unit, Heavily ported 081 heads, 1 7/8" primary headers, 2,800 stall, 3.73s, etc.
Attached Thumbnails Old Skewl TBI camshaft-cam-1.jpg   Old Skewl TBI camshaft-cam2.jpg   Old Skewl TBI camshaft-cam-3.jpg
Old Apr 25, 2006 | 12:20 PM
  #50
BMmonteSS's Avatar
Car: 84' Monte
I thought the cam you were running was like a 234/244? The cam he is claiming to run is a full 20 deg bigger........That's alot.......not to mention on a bone stock 305.
I would have a completely different attitude in this thread if it would have just started like this:
Hey all, I've gone against the grain and put a huge honkin cam in my stock 305, I know it's not the best choice for power but I love the big cam sound. So here's what I had the most problems with and how I was able to make it work.
That would have been perfect, but all we got was I put this cam in and now it's Fa$T as shiznits and $OUnDs Aw$s0Me. I dunno just strikes a chord with me.
