Best Engine to swap?
Old May 27, 2006 | 01:24 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
I'm not sure if this is the right forum for this topic but I am considering putting a GM Crate motor into my Camaro.. I currently have a 305 tbi.. I have people who can swap the engine for me since I don't have the experience. But what are the things i should consider? Here is the crate motor i am wanting to purchase.. Is it to big of a hassle or to expensive to put in? Or is it cheaper just to build up my 305?
290HP / 350 Long Block Pre-Emissions GM Crate Engine :: 12499529 - SDPC
or something like this?
http://www.sdpc2000.com/catalog/120/...e-Assembly.htm
Old May 28, 2006 | 10:01 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I would go with the second choice but unless you plan to ditch TBI and go carb save a few bucks and just get the standard version. From what I've read in several posts on this site TBI can feed this engine. Just plan on some funds being spent on programming and a few upgrades to the TBI and fuel system.
Old May 28, 2006 | 12:00 PM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
Transmission: Built 700R4 w/ 2500 stall
Axle/Gears: 3:73 posi
just take your time and research it alot, you dont want to be unhappy with that expensive of investment.
You can come across 330 hp for cheaper than $4500, ill tell you that much right now.
Old May 28, 2006 | 11:56 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
i actually just might stick to the old 305 and learn how to do **** myself.. Im buying a programmer next week
Old May 29, 2006 | 01:42 AM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
That, and if you leave your heritage all original, it will be worth ALOT of money some day.
I'm not sure if you're in it for that long of a haul though.
xkingcodex
Feb 12, 2020 07:43 PM
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
