pushrod length
Old Jun 6, 2006 | 11:14 PM
camaro25thrs's Avatar
Car: 87 iroc
pushrod length
You guys who r using the lt1 cam r u using the stock pushrods?
Old Jun 8, 2006 | 08:57 PM
Car: 87 iroc
SO is that a yes that everyone thats runnig the lt1 cam in their lo3 is reuseing their stock pushrod?
Old Jun 9, 2006 | 11:09 PM
93C2500ext's Avatar
Lo3s are roller cam right? So the pushrods should be the same. If you are putting the lt1 roller in a non roller engine you have to get the shorter pushrods because the roller lifters are taller than the flat hyd ones.
Old Jun 11, 2006 | 05:13 PM
Car: 87 iroc
Yes its a hyd. roller motor lo3 but the lo3 cam is smaller then the lt1 cam so I was wondering if it would use the same size pushrods?
Old Jun 11, 2006 | 07:39 PM
93C2500ext's Avatar
No, The adjustment on the nuts for your rocker arms makes up for the .050 or so increase in lift of the LT1 cam over the l03. Jon
To Clarify - You can use the same pushrods because the lift increase with the LT1 cam is not enough to require custom length pushrods. Jon
Last edited by 93C2500ext; Jun 11, 2006 at 07:42 PM. Reason: Automerged Doublepost
wigmobile
Feb 26, 2025 02:56 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mfp189
Sep 27, 2015 09:25 AM
Scorched1984
Sep 15, 2015 03:42 PM
