would a lt1 cam swap be worth it with my set up?
Old Jun 12, 2006 | 12:22 PM
92rsvortec350's Avatar
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
Please read my sig. for my set up
now I was thinking about a lt1 cam and rr's in hopes to getting closer to 12's but Iam not sure how much power I would see over the stock l31 cam I have now I think it is a 410 427 lift or close to it (if you know the stock vortec 350 cam specs please post)
I would go with something bigger but I have vortec heads and I dont want to pull em so the lt1 cam is at its lift limmits
so would the power gain be worth it? and how much power do you think I would gain?
Thanks for any input.
Old Jun 12, 2006 | 06:38 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
191/196 @ .050, .418/.430" lift, 111 LSA, installed on a 112" Intake Centerline (atleast on the 1997 G1500 350 that is in my garage (hole through block due to intake gaskets and hydraulic (coolant) lock).
The B-body LT1 uses the same cam as the Vortec 350. The Vortec heads are essentially copies of the IRON LT1 heads. The B-Body was rated 260 FWHP/335 FT/LBS vs 245/335 of a vortec truck. The Iron head F-body LT1 with a single catalyst was 275 FWHP/340 TQ. The cam was worth about 25 HP in stock form but the single cat probably choked 10 FWHP out of the combo. With headers, better exhaust, carb intake, tuning, etc, I could see 30+ FWHP from the cam swap alone.
I've got the LT4 cam in my 365 Vortec in my G1500 Express (Marine intake, Headers, Later model high flow cats, Flowmaster 50 series, OBDII tuning). A spring is available on the market to allow HIGH lifts on otherwise stock Vortec heads. I forget who makes it, but it is common knowledge on Fullsizechevy.com.
Yeah, I've got 3 vans, oh well.
Old Jun 12, 2006 | 07:41 PM
DM91RS's Avatar
Car: 91 RS
I am running the Vortec's with .480 lift by using offset retainer locks. Crane makes them.
The springs Fast is referring to are probably Manley's. I have a set to go on but you will still need to cut down the guides for more than the above lift.
Old Jun 14, 2006 | 08:57 AM
Engine: forged 350
Thanks yall, can you give me the part #'s for the ret. locks dm91rs?
and what cam are you running with your vortecs?
and one more what springs should I run with the lt1 cam that will fit stock vortecs?
Old Jun 16, 2006 | 04:42 AM
DM91RS's Avatar
Car: 91 RS
It will be tonight or Sat before I can return home and find the part # but I have it and I am running the stock LT4 cam with 1.6 rockers for .480 max lift.
Crane springs of which I will give you the # for also if you are interested.
Later
Old Jun 16, 2006 | 10:13 AM
Engine: forged 350
yea both part #'s would be great thanks.
Old Jun 16, 2006 | 01:35 PM
DM91RS's Avatar
Car: 91 RS
Manley springs PN 22410-16
Crane valve locks (yellow) +.050 PN 99095-1
Old Jun 16, 2006 | 02:04 PM
Engine: forged 350
so are you running the stock springs with the crane locks?
and whats your cam specs?
Old Jun 16, 2006 | 04:47 PM
DM91RS's Avatar
Car: 91 RS
Springs are Cranes....I have the Manley's to install when I refresh the heads. I recommend the Manley's because they are taller and do not need the shims under them that I have now with the cranes.
LT4 stock cam Dur. @ .050 206/210 Lift with 1.6 Rockers 476/480
Old Jun 19, 2006 | 08:48 AM
Engine: forged 350
Ok thanks for the info.
Old Jun 25, 2006 | 09:30 AM
Brent's Avatar
I don't see any mention of what torque converter you have. If its a tight stockish converter you probably want to use a stockish cams. It just depends on your starting line situation and how much traction you have vs how much torque. If it drives off the line at WOT with no tire spin, increasing cam duration will probably hurt your 60ft time. On the other hand, if its hard to get out of the hole without spinning the tires, losing a little torque will make it easier to launch.
1984HO
Mar 19, 2021 11:59 AM
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
