dual snorkel intake
Old Jul 10, 2006 | 11:32 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
dual snorkel intake
my 305 tbi has the a/c still in it and i dont want an open element but i want a dual snorkel intake off an L69 i think it is. how could i go about fitting the passenger side hose there anybody done it?
Old Jul 10, 2006 | 11:37 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
I'm an open element case but have you looked at running the second hose under the first?
Old Jul 11, 2006 | 09:56 AM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
the dual snorkels are still fairly restictive. they flow pretty good but not as good as an open element. if you dont mind my asking why dont you want to go the open element route(im curious)
Old Jul 11, 2006 | 01:03 PM
Engine: LO3
well for some reason i find my car performs better with colder air from the single snorkel i have now compared to hot air. plus i just like the look of the scoops and hoses even though it can get messy.
if i ran the second hose under the first where could i put the scoop?
Old Jul 11, 2006 | 06:43 PM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
I'm facing that dilema right now too. I have not put hoses on it yet (don't have any), but I am considering removing the coolant reservoir and replacing it with a smaller one from a different car to gain some extra space, but I haven't thought real hard about it yet....I'm running out of money.
Old Jul 11, 2006 | 07:39 PM
Ricks Trans Am's Avatar
Car: 1985 trans Am
Engine: 305ci
Axle/Gears: Borg Warner 9 bolt 3:27
can you tell me where you found dual snorkel setup. have been trying to locate one, air cleaner and plastic intake pieces
Old Jul 11, 2006 | 08:59 PM
DLV555's Avatar
Engine: 400 SBC
Axle/Gears: 4.10
Ebay. They don't come cheap, but I bought mine for $60. Just the air cleaner and lid though. Of course I ditched the lid for the taller truck lid.
Old Jul 11, 2006 | 09:11 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
I went the dual snorkel route for cold air also. As it sits now with no hoses, its warm air intake, and I can feel it. After sitting at a light and cooking, its like a slug until the hot air clears out. HoWeVeR, as long as the temp guage is readin about 180, it revs more then it ever wanted to with the single snorkel.
As for making it cold air, I'm having a terrible time trying to find a passengar side scoop. PLUS, the a/c junk and overflow tank completely block anything.
If I do not relocate the overflow someplace else or get a smaller one, I may venture at getting a 4th gen overflow. They mount underneath the battery. A perfect solution, but modding to fit looks like a pain.
Old Jul 11, 2006 | 11:40 PM
Engine: LO3
first off does the truck cover fit under a stock firebird hood?
second what if the driver side hose it hooked up then leave the passenger side open then its somewhat cold and somewhat warm so you have somewhat cooler air with overall double the airflow.
Old Jul 12, 2006 | 12:10 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
I thought about hooking up the drivers side and leaving go the passengar side, but I was afraid of some kind of wierd vacuum affect. Something like cold air being more dense would want to be sucked back out the open passenger side. I could just be paranoid .
Old Jul 12, 2006 | 09:20 PM
Engine: LO3
i dont think so because cold air is just more dense so it would sink lower if anything
Old Jul 12, 2006 | 10:47 PM
305tbier's Avatar
Car: '92 firebird
Engine: 305tbi
Transmission: th350
Axle/Gears: moser 28 spline 3.73 eaton posi
Check with ramairbox.com (Air Inlet Systems). One of their dual snorkels may be easier to fit, and would definitely flow better. Would need a drop base with a stock hood.
Hooking up the drivers side tube only wouldn't make any diff, except the engine wouldn't be getting as cool a charge as if both were hooked up. The side with the least resistance(probably the passenger side) will draw more air, unless the tube(s) are set up for ram.
Old Jul 13, 2006 | 11:01 AM
sully91rs's Avatar
Car: 91 RS, 95 Z28
I never saw ramairbox.com before. They have reproduction left hand snorkels. Too bad it costs sixty smacks.
Old Jul 27, 2006 | 11:19 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
I just got an email quote the other day from Ram Air Box, about their dual snorkel setup...
-----Original Message-----
To: ramairbx@wchat.on.ca
>Good afternoon, just wanted to know if you still had the dual snorkel
setups for a holley carb'd 87 camaro. I already have a 14x3 K&N, would i
still be able to use this in your setup? How much does it cost?
Kit # D14x3@110 HO
It is a factory appearing set up.
Emulates the factory High Output Camaro Z-28 & Firebird Trans-Am
system found on the 1984-85-86 HO cars. Uses factory style black tubes with
factory style left & right intake snorkels.
We can also supply you with any / all components individually so you can
assemble your own kit to your own specs.
The factory snorkels were originally sold made of plastic
part #'s 14070917LH and 14070918RH have been discontinued by GM
We now reproduce these parts
These are sold as AIS part # 917 & 918
They are fiberglass reproductions of the originals.
They go for $42.50 Each.
Full kit Part # D14x3@110 stg II H.O. includes:
The #14x3@110 RAM AIR BOX,
2x # G28108 stock type intake tube,
#917 & #918 F-Body High Output Intakes,
#14AL/CCover Aluminium cover,
#AF3 14x3" air filter
#14AL/DBase
Aluminium base, stud, nut, instruction pack.
Is $345.45US incl. S&H
options:
NEO4 neoprene black tubing +$49
AF3-KN, K&N washable air filter +$49
You may place your order over the phone with Visa, M/C, Discover or AmEx.
(905) 549-6135, 8AM to 5PM Monday to Friday.
If you need assistance, don't hesitate to call.
+++HAVE YOU SEEN OUR WEB SITE!+++
-Check out:
Ram Air Box
-Testemonial of performance on 68 MUSTANG:
FORDMUSCLE.com RAM AIR BOX
--98 DODGE DAKOTA install:
Monte Carlo SS PaulC's 86 SS
----67 Pontiac GTO With RAM AIR BOX:
Classical Pontiac Feature Car
-----66 Olds F-86
Rich's Homepage->Automotive Links->1966 Olds F-85
------94-01 Dodge Ram Truck with 318 or 360 CID
http://home.talkcity.com/ThePits/rm_...mairsetup.html
Pierre Lafontaine
AIS
(905) 549-6135
Old Jul 27, 2006 | 12:01 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Nice work Tob. $43 is better then $60. They should update their sites price list.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Djmathis123
Sep 8, 2015 08:42 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
