TBI and cam overlap
Old Aug 12, 2006 | 11:07 AM
Casey Butt's Avatar
Car: 1988 IROC-Z TBI
Engine: L04.3 = 305-310-336
Transmission: TH-700R4
Axle/Gears: 10-bolt, 3.42 posi
TBI and cam overlap
I'm looking at having a cam made with 43* overlap for a 334 TBI motor. The duration at 0.050" will be around 210/220 int/exh on a 112 LCA. Compression ratio should be ~10.0-10.1:1, which should give me about 16-17 inHg. I've used 37* overlap in the past and this required only minimal "tuning" of the EPROM, so I'm wondering about 43* overlap? Of course, I intend to re-tune, but I'm wondering how the car will fire-up and idle with the old chip. Any insights?
Old Aug 14, 2006 | 12:09 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
With speed density and TBI its a complete crap shoot. The only way to find out is to turn the key and see what it does. Thats not a real big cam, so my guess would be that it should start up and idle in some fashion.
Old Aug 14, 2006 | 09:45 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
My 350 Xfire uses 54d of overlap on a 108LSA. When warm, motor fires at "key on". Needs a couple of cranks when cold. Idles a 47kPa.
Old Aug 14, 2006 | 10:01 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
My 312 with the L82 cam ran 61.5* overlap on a 114* LSA. After a little work on the VE tables and timing table, fired right up and idled at 60 KPA/ 750 RPM in Park/Neutral and 75 KPA/800 RPM in Drive. With the A/C on that number dropped to 80-85 KPA/900 RPM in Drive.
Fired on the first hit of the key, everytime. Idle timing was about 30* BTDC and the initial timing at the distributer was 18* BTDC.
Old Aug 14, 2006 | 10:50 PM
Casey Butt's Avatar
Well, I'm having the cam custom ground, so I can tighten up the LCA to 110* - which should be better for the stroked motor anyway - but that would give me 47* overlap on a 110 LCA. 210* should put the power in the range that I want it and I want the extra 10 degrees on the exhaust (220*) to account for any valve shrouding on the exhaust side with the square engine.
I'd prefer to go with 110* LCA but I don't want to make the idle MAP signal jumpy and cause tuning issues. Anyone see a "problem" with 210*/220* @ 0.05" and a 110* LCA (47* overlap)? I'd much prefer to go with that.
Dominic and Fast, how did you find tuning those cams?
Old Aug 14, 2006 | 10:57 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Its definately workeable with the right tuning and a good match-up on the rest of the components.
If you end up with the EBL you shouldn't have any problems getting it dialed in after some work.
FWIW, my L82 cam was 291/287 @ .008", 224/224 @ .050, 114 LSA, .450/.461",
Old Aug 14, 2006 | 11:42 PM
Casey Butt's Avatar
Were you using EBL or tuning the tables on the stock type chip?
Old Aug 14, 2006 | 11:45 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Pre-EBL on a 7747 ECM
Old Aug 15, 2006 | 09:02 AM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
[/COLOR]
Casey,
Both cams I have had in the car are CompCams HR. So you could add about 10d of duration for a comparable flat tappet cam. The first one is similar to what you are thinking about. It was a 264/270 adv.(212/218 .050) with .488/.495 lift at 112LSA. It idled very smoothly at 800rpm using just a 7747. Lots of torque. EBL makes tuning these cams much more feasible due to the granularity of the VE and SA tables along with several ancillary controls.
MustangBeater20
Oct 29, 2022 09:20 PM
junkcltr
Aug 2, 2019 11:12 PM
509 camaro fan
Sep 6, 2015 10:43 AM
z28addict8490
Sep 5, 2015 03:56 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
