Nightmare with my TBI at the track
Old Aug 26, 2006 | 08:28 AM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Well I was only able to pull in two runs, my first was a 16.04 followed by a 17.02 because of massive spinning issues. The point of this post is to ask what my cars potential should be because on my 16.04 run I pulled a 2.2 60 foot. I would hope after all of the work ive done that its just me and not the car. On my first pass I launched at 2000rpm and still spun but that was better than the 3000rpm the second time. What is the cars potential guys this is upsetting lol? Any tips on how to keep the radial t/a's from smoking up every time?
Old Aug 26, 2006 | 09:31 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
We could tell alot more from all the times on your time slip, MPH is the important thing. You've basically have a full exhaust, so bottom 16's isn't bad, you probably have more left in it with a good launch. Maybe a 15.8ish, hard to tell.
Old Aug 26, 2006 | 05:25 PM
Engine: LB9, LB9
Well its a five speed and I have heard with bolt ons they can run a low 15. on my best run the times were:
60 foot: 2.403
330: 6.718
1/8: 10.344 @ 68.36 mph
1000: 13.423
1/4 mile : 16.047 @ 86.22 mph
Old Aug 26, 2006 | 05:42 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Get that 60' down and you'll be much better. You should be faster with the 5speed car. With an open element, 3.42's and flowmaster muffler on stock pipes I was able to cut a 2.2 60' and get a 15.7 at 87. You should be able to do better than that MPH. Mine's heavier and you have full exhaust. Get the 60' down, maybe do a tune up on it, cap and rotor and plugs.
Old Aug 26, 2006 | 05:45 PM
Engine: LB9, LB9
It has a fresh tune up, but I cant find a good launching point and it spins bad, if I could stop that I would hope it would be faster.
Old Aug 26, 2006 | 05:49 PM
BronYrAur's Avatar
Engine: 305 TBI
Well, then you pretty much just told yourself what your next mod should be. That 2.2 60' I cut was launching hard and for the first time ever at the track. Because I had 3.42 gears and POSI. That is the key here, pick up a good posi unit and some gears, you'll love the decision after you do it believe me.
Old Aug 26, 2006 | 06:07 PM
Engine: LB9, LB9
This guy offered me a set of S-10 3.73 gears and a spool lol for $100, is that worth it or is a spool horrible for daily driver?
Old Aug 26, 2006 | 06:12 PM
BronYrAur's Avatar
Engine: 305 TBI
nah you don't want a spool. I got a 3 series zexel torsen posi carrier with 3.42 gears for $170 shipped. I found that off of ebay and it had about 10k miles on it. If I were to do it again, I would definitely find a torsen rear like I did, I like it a lot. But, any posi unit will work fine, but you would hate a spool setup.
Old Aug 26, 2006 | 09:30 PM
vwdave's Avatar
Radial T/A's should be called Spinner T/A's. I have never had a good launch on mine. (Mine are 265/50/15's)
Get a 3.42 Posi and some LCA's. The LCA's will reduce wheelhop dramatically.
Old Aug 27, 2006 | 08:15 PM
JustinSane's Avatar
man this has me worried i am going to run my 91 rs this weekend at the track and its bone stock the only mods are 2 degrees timing and a truck air cleaner base plumbed for cold air. its a auto with 2.73 gears and i am almost certain it will be in the low 16 to high 15s I will be sure to let yah know how it runs. As long as i can cut a low light and it runs consistant times I will go rounds and thats what matters any way its gonna be a big change from my nova so i may not figure the light out fast anough
Old Sep 6, 2006 | 02:38 PM
joe91cam's Avatar
Car: 1991 camaro rs
Engine: 5.0
if u dont want that spool let me know for a 100 dollars i cant even find one
my car runs a 15.6
3.52 gears posi
edelbrock open air element
msd blaster
accel 7mm plugs
accel cap and rotor
headers
Old Sep 6, 2006 | 02:41 PM
joe91cam's Avatar
Car: 1991 camaro rs
Engine: 5.0
my car runs a 15.6 at 89
3.52 gears posi
msd blaster
accel 7mm plugs
accel cap and rotor
headers
nos not sprayed yet
i can sometimes get a 2.1 60' other wise it goes 2.2 in the 60'
Old Sep 7, 2006 | 10:50 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
Hey man I have a 92 and its stock also with mild mods likeopen element,cowl hood,stock exhaust with flowmaster.spacer plate...smog delete,and its a
T-5, 5.0 alsowith an open 3.08I am running on an eighth mile track.
I'm gonna try to post my best time....you cant hardly read it cause it has been in my wallet....round here .500 is perfect reaction time....I'm #102
Old Sep 12, 2006 | 01:25 PM
joe91cam's Avatar
Car: 1991 camaro rs
Engine: 5.0
tomorow ill be sprayin the car at the track ill post my times then
Old Sep 17, 2006 | 11:55 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Joe91, were are you running at? Just moved out to KC,MO!
Old Nov 6, 2006 | 10:33 AM
joe91cam's Avatar
Car: 1991 camaro rs
Engine: 5.0
i run at heartland park topeka i didnt get to run because i messed up and thought that when i ran was going to be the last track day but i was wrong it was the time before so i didnt get to run they also got kcir and that would be closer but ive never been there
BLK87Z
Sep 18, 2015 11:29 PM
89bird2.8
Sep 18, 2015 07:46 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
