What is the formula ?
Old Sep 18, 2006 | 05:50 PM
gofast51's Avatar
Does anybody know the formula for determining at what rpm your injectors theoretically go static? I've seen Rbob use that in several posts and it would be helpful to have when building a motor or installing a new cam etc...
Old Sep 19, 2006 | 01:40 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
What I use is a small program that makes the same calculations as the ECM does. Basically it is:
PW = BPC * ~AFR * ~T * MAP * VE% * BatCor + InjectorBias
Then do some calc's based on RPM for duty cycle.
The inverse AFR and T (temperature) are from table lookups. And the MAP is a value calculated from the actual MAP value.
So it isn't easy to have a formula to use.
RBob.
Old Sep 19, 2006 | 03:41 PM
gofast51's Avatar
Thanks for the reply Rbob. I guess I shoulda been careful what I asked for. I think it still would be great info to have . Maybe somebody with all the skills could write us a program to help with the calcs????????
Linson
Oct 24, 2025 02:00 PM
okfoz
Oct 13, 2015 02:19 PM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
