need help fast
Old Nov 1, 2006 | 10:13 AM
t-rex_camaro's Avatar
Car: 1991 camaro rs
Transmission: auto
Axle/Gears: 2 axles and a set of gears
need help fast
ok i have a 1991 305. its got a .465 .465 lift cam with full roller 1.6 rocker arms.... and for months it was runing fine.. then on monday i started up my car after school and it started nocking after 1500 rpm.. then today and yesterday.. it would backfire while worming up and still nock after 1500 rpm. i changed the plugs and checked the cap and roter and they look fine to me.. do you guys think it could be a bent valve. it didnt do that till after school it worked fine on the drive to school.
Old Nov 1, 2006 | 02:58 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Well, are your heads prepped to handle that big of a cam? What valve springs are you running, and is that .465 the rating with 1.5's?
Old Nov 1, 2006 | 04:52 PM
Car: 1991 camaro rs
Transmission: auto
that is .465 with 1.5s so its like around .496 with 1.6s but i found out what was wrong it was a worn down tappet. it looks like a bowl in the middle and the cam is ok i took it out a looked it over and it is all good. so thanks anyways but i found the prob.
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
sreZ28
Oct 22, 2015 08:21 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
