Issues, Need help!
Old Nov 6, 2006 | 02:48 PM
Pretty Waste's Avatar
Car: 1992 Chevy Camaro RS
Transmission: m5
Issues, Need help!
So we bought a 1989 RS yesterday and in the ad it said bad fuel pump. So we get the car home and my dad turns the key and notices that the fuel pump is running fine. Super. So there is something else
We changed the inline fuel filter and we're still having problems getting gas from the tank to the Injectors so.. We did some tests, called some people.. and we haven't had much luck.
If you rip the fuel line, the fuel pump is running gas out of the tank, It is hitting the filter and going through. If you pour gas on the thing, it will start up and run, until running out of gas.
Today we changed the "Igntion Modual" and still had no luck
Does anyone here have any advice as to what to ccheck, or what the problem could be?
Old Nov 6, 2006 | 03:34 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
sounds like the pump if you take the air cleaner off and watch the injector pod you should be able to see it spray gas into the motor when you turn it over if not then it is time for a new pump!
Old Nov 6, 2006 | 03:59 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Even if you see gas, it is no proof. You need to check the pressure. In stock form, there is not fuel pressure port though. Since it runs with gas being poured in, it is fuel related. If you are mechanical at all (it sounds as though you are), you can pull the tank and put a new pump in, in 3-4 hours.
--John
Old Nov 6, 2006 | 04:01 PM
Transmission: m5
That is an option in the long run, but we really do not think that its the fuel pump. You can hear the fuel pump running, when you turn the car on. I'm looking for other things that it might possibly be, and if all else fails, we could redo the fuel pump...
Old Nov 6, 2006 | 05:08 PM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
the problem is these pumps dont always just die some times they fade out
they make some pressure but not as much as needed for the injectors to work correctly
Old Nov 6, 2006 | 05:12 PM
Transmission: m5
Okay.. I will check all this when I get home.
Any more input would be appreciated.
Old Nov 6, 2006 | 05:21 PM
Car: 1991 camaro RS
also just check the injectors see if there spraying
if they are not spraying check the fuel system psi as just to make sure
as dropping the rear and tank seem like a big pain just to change the fuel pump
Old Nov 6, 2006 | 06:07 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Don't rule it out, it may not be making pressure, or pumping much of any fuel. heck, even the sock filter could be clogged, so it isn't picking any fuel up. Or in the case of my last fuel issue, the rubber connector for the pump to the fuel line system burst.
It is obviously fuel related. There isn't a lot to the fuel systems in these cars. I would test the fuel pressure, if it is not rock solid at 12psi, I would start looking at the pump.
Old Nov 7, 2006 | 09:03 AM
Transmission: m5
Thanks for all the help!
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
