TBI S/C?
Car: 88 GTA
Axle/Gears: 3.27 9bolt
TBI S/C?
I saw a SMall blowwer 144 or 177 somewere a couple years ago for TBI SMall block GM's. Anyone know were to get these?
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
http://www.holley.com/division/Weiand.asp
Scroll down to superchargers and there are 4 SB Chevy SC. A 142, 144, 177, 250, 6-71, 8-71. Thats all of them in order top to bottom, left to right.
Car: 1991 Camaro RS
Engine: L03 5.0L
Axle/Gears: 3.08
I am currently working on a project using an Eaton M90 and adapting that to a 305 TBI. You can pick that blower up at any junk yard for roughly $200 (I've see them aqs low as 50) and Corky Bell's guide to supercharging is like $20. If you use a Ford Thunderbird S/C as a guide car and you aren't half bad at fabrication of custom parts you can have yourself a COMPLETE blower setup for less than $350. Only challenge is tuning!!! You'll need to do all the "Ultimate TBI" upgrades first including fuel pump from a TPI car, and you need Injectors Larger than the ones found on the 454 TBI. But it can be done! Mine should be done in... well, lets not get ahead of ourselves :-)
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
3rd-gen junkie, are you making it into a blow-through setup ? i.e. like a centrifugal s/c or are you making it into a roots style blower setup ?
Car: 1991 Camaro RS
Engine: L03 5.0L
Axle/Gears: 3.08
Roots style, air to air intercooled, blow thru TBI
The best of both worlds, using a roots like a centrifual. Dual roots is down the road...
Last edited by 3rd-gen junkie; Nov 16, 2006 at 03:37 PM. Reason: Automerged Doublepost
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
1 M90 is going to be REALLY working to try to feed a 305. the M90, run's at about a 2:1 drive ration, that gives you 180ci of air per revolution. Even being gneration, and saying the 305 need only 85% its CID in air-flow, that means we need 130ci of air per revolution. that gives us about a 1.3 pressure ratio. BUT WAIT, there's more. I don't think an eaton will even do 70% effeciancy, but we will go with that, at 70% effeciancy (it creates heat to pressurize air, as you heat it, you get less density), you end up with a .96 pressure ratio. I really don't see a single M90 making over 300hp, under any conditions.
A guy with a PAIR of M90's in his garage, just making an observation.
I would also suggest going with EBL to try to get the computer to play nice. Plan on some big injectors, and big fuel presure. Rember, you need to up the fuel pressure in at least a 1:1 ratio with the boost. If you are using TBI, the injectors will be under boost, and if you don't raise the pressure with the boost, you are effectivly lowering your FP as your boost goes up.
On another note, didn't Fast do a 144 on top of the 350 in his van?
--John
--John
Car: 1983 G20 Chevy
Transmission: 4L60
--John
http://www.youtube.com/watch?v=DPIaLtE_U1I
I backed off around 50 when the rear end started getting a little sideways.
I also did a TBI 305 with pair of ported TBI 350 heads and a Vortec truck cam a few years ago.
Car: 1991 Camaro RS
Engine: L03 5.0L
Axle/Gears: 3.08
Well thus far my research indicates an M90 is suitable for all hte way up to a 350. Keep in mind I am planning on using a gen 5 with overdrive pulley. I designed an adapter that only utilizes the blower when under boost b/c of the blow thru setup. As for normal driving car functions like a N/A engine. But as for this van, did you blow thru TBI as well?
But I plan on using fuel pump from a TPI car, injectors from a 454 TBI, and the overdrive pulley on the blower. A friend who does M90's on 3.8L cars is pushing up to 15 pounds from his M90 setup... I am expecting 7-8 pounds max. All calculations were done using Corky Bell's formulas. ADVICE AND TIPS ARE GREATLY APPRECIATED.!!!
Car: 1983 G20 Chevy
Transmission: 4L60
No my 142 was draw through but the fuel pressure was boost referenced. 15 PSI @ idle, 23 psi with the vacuum line off the regulator, and about 30 PSI at 7 PSI of boost. It drove just like a normal van, until I layed into it. At 1/2 - 2/3 throttle not in PE the transmission would flare between shifts pretty bad.
http://www.youtube.com/watch?v=JwWio6o9NHQ
Also keep in mind that this 350 has Stock HD swirl port castings, Peanut Roller cam, and cast iron exhaust manifolds at the time.
Car: Chevy Caprice
Engine: 350 TBI LO5
So Fast, if you had a stock 350 TBI like me, what would be the parts that're required to install a supercharger/blower and have it run smoothly? (To the best of your knowledge, now that you've completed it once) I could never affored this, so I'm simply wondering.
rs_z28_vert
Sep 30, 2015 09:47 PM
