TBI Unit selection
TBI Unit selection
Has anyone used the ExtremeFI 50mm bored out tbi units? I picked up a 502-6 holley unit, i'm just wondering if I should maybe go with one of their units instead so I don't have to mess with any wiring or linkages on the holley (I also have someone interested in it). They say theirs' flow 750cfm with the ultimate mods.
Thanks.
Thanks.
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
lol right people or just lazy to reply
but ahh i heard that the extremes are real good and even better then the holley 670s but who knows im also looking for a new throttle body hmmm i thought about the holly commander but dam thats to much money for that but then agian u get wat u payed for
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
50mm is 50mm doesn't really matter who makes it. You can't really do the ultimate TBI mods to a 50mm throttle body since there isn't a ridge like the stock sb units.
Car: 92 camaro rs
Engine: 350 tbi/416's/comp xe268
honestly i feel like keeping stock unit doing ultimate tbi mods is the way to go esp. if you go with the 68lb/hr cop car injectors with a walbro 190 fuel pump
What tb unit do you run BMmonteSS? I was mostly curious whether or not the extremefi unit would be a better choice from a plug & play perspective. They claim theirs flows about 80cfm more than the holley. I was just wondering if anyone has actually used it. This will be fueling a 383 so I want to make sure I get the right unit so as not to starve the engine.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 84' Monte
I'm running a BB unit, I had to fabricate the throttle linkage because I swaped TBI into a carbureted car. You'll also have to get the correct connectors for the IAC and TPS. They may or may not match up with your stock connectors.
As for the extreme unit flowing more than the holley.....they don't do anything to their TB's that you couldn't do to your own. My guess is they radius the entry into the throttle bores a bit and add an injector spacer and claim the 80 cfm. In the end it really doesn't matter, I picked up my TB for $20 so I made it work. You also need to make sure your getting the bigger injectors with the extreme EFI unit. 80/90 lb injectors aren't cheap, but if your getting them with they BB unit then it could be much cheaper in the long run.
Glowsock
Sep 5, 2015 07:48 PM
