Need some carb Vs. TBI help please!
Old Oct 29, 2000 | 08:29 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
I'm in the middle of building a killer 427 small block, I'm going for 600 hp. I have already assembled the intake assembly (Offey duel quad manifold, Turbo City carb to TBI adapters, 2 Holley 670 CFM TBI units, custom wiring harness, and It still needs a custom chip. Someone wants to buy the whole thing from me though, for more then what it cost me to build it, but I don't really know if I should go through all the trouble again of grinding the adapter and such to fit the TBI's blades in.
My question is, do you guys think that that setup would feed this thing to 600 hp? The engine will be capable of producing that power N/A, it's just the intake system now. Should I go the cheaper route and go with duel quads or a Dominator, or should I really try to inject this thing? Oh, and don't try to detur me from using duel quads because their tough to tune, I've done this plenty of times on other vehicles and it's not much of a challange for me.
I need opinions please!
Old Oct 29, 2000 | 08:34 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
if you did dual tbi i would hail you
even more so if you went with a single plane mpfi conversion with a billet 1000 cfm tb from force-efi.com or something like that
Old Oct 29, 2000 | 08:53 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Hmmm.. I like that sound of that MPFI with the 1000 CFM throttle body. A supercharger would go nicely with that.....
1992 RS
327, Modded TBI, Rebuilt WC T-5 5-speed, PRO 4 15" rims, Nitto's, 3.73's, SLP 1 5/8" headers, and a few other things.
Old Oct 29, 2000 | 11:27 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
DUKE!!!!! WHAT HAVE YOU DONE??!!!!
That would be pretty neat with the Dual TBI deal. But it would it work? Who knows. Would take probably some REAL fine tuning. I go with what the hodrodders use. Carb. Hey, they have to know something we don't about these things!
Eric Natzke
91 Firebird 305 TBI (ZZ4 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-Accel Cap & Rotor
-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone
http://members.aol.com/j007golden/91firebird.html
[This message has been edited by 91Bird305 (edited October 29, 2000).]
Old Oct 30, 2000 | 11:11 AM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
The duel TBI does work, I've already used it on my 327, just to test it, but it ran well. It was running somewhat rich, but I only had two PROMS burned for testing. At the time I was using two GM TBI units, now I have two Holley 670 TBI units, but haven't tested those yet, they'll never work on the 327, it's just too much. As for tuning, I'm going into the PROM burning business so I can make my own PROMS and I can make some money doing it for other people. I'mm still considering the carbs though if I do sell the fuelie setup. And I really like Pablo's idea.
1992 RS
Old Oct 30, 2000 | 03:58 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Well whatever you decide post back what happened so maybe it can some of us some idea for the future too. Thanks Duke.
Eric Natzke
Old Oct 30, 2000 | 05:40 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
Turbo city claims on their webpage that the dual tbi setup will go to 600 dont they?
Id trust em, and if it doesnt, o no, you've got 550hp. darn. we could all be so lucky.
I make a buck whenever i can, if somebody wanted to buy something i built, and i could make $$. ide sell it, cuz its always better and easier the second time around.
So hed have the ok one, and youd have the perfect one, learning from your first mistakes.
This is COMPLETELY NUTS, but.
tri-power
3 little tbis?
Old Oct 30, 2000 | 10:25 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
I decided today. I had to, the guy said today or never. I already have everything, and I got everything dirt cheap, so I'm keeping it. With an Offey duel quad intake, turbocity adapter plates (these things are a bitch to grind to make the 670 blades fit), 2 Holley 670 CFM throttle bodies (one with requlator, one without, a wiring harness I made on my very own with automatic injector calibrators, a custom chip, and a normal GM TBI ECU, this 427 is gonna kick some serious *** . And with the TBI's greater torque combined with a 427's already awesome torque, I'll be breaking driveshafts and rearends at every light. Oh yeah, it's a small block.
1992 RS
Old Oct 30, 2000 | 10:53 PM
snflupigus's Avatar
could you explain to me how the dual tbi works. one with regulator one without. why is this, and how do you get the injectors to self calibrate.
Please, this sounds very interesting to me.
Old Oct 31, 2000 | 08:02 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Very well.
The reason you use only one regulator is because the return fuel line from the regulated TBI feeds the other TBI.
What I mean by self calibrating is each injector fires in order.
1 3 (rear TBI)
4 2 (front TBI)
Does that make sense?
Here's what the Turbo City one looks like:
1992 RS
Old Oct 31, 2000 | 08:07 PM
snflupigus's Avatar
Yes ive seen the set-up.
And that does make sense, with the injectors. I was assuming the return line has something to do with it. So the second tbi is like pablo's with an external regulator and no return line, then the first tbi would be like a factory one, with the return line now being the feed line to #2. That makes sense, ya. Does the return line of the second return or do you have it plugged.
Old Nov 1, 2000 | 08:14 AM
scauffiel's Avatar
Hey Duke, glad to hear your dual setup is working out - I'm kind of holding off on mine, because I think it may be too much for my 383 - at least until I get the twin turbo's in there. I made an adapter plate out of the 'ole cutting board for mine - no problemo grinding that, at $8 it was damn cheap AND it keeps the heat out of the TBI's a bit better than aluminum.
I would like to see how you did the wiring harness; I don't want to make the mistake of buying Turbo City's and then have to mod it just to make it work - could you send me some pix or do you have it up on your web site yet?
Just in case any of y'all would like to see pix of a dual Holley setup on an Edelbrock manifold...
Yeah Baby YEAH!!
Steve
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
Billy Decker
Sep 4, 2015 03:46 PM
