Opem Element?
Old Nov 2, 2000 | 09:13 PM
91FastBird60kmiles's Avatar
Opem Element?
Ok, guys i want to get an open element air cleaner.
Wich K&N should i use?(jegs part #'s please)
Will a 14x3 fit under stock firebird hood?
What kind of hp gains should i expect?
Old Nov 3, 2000 | 08:47 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Hello my friend,
14x2.25 is #KNN-601263
14x3 is #KNN-601280
As for which one, I went with the 14x2.25 because my spacer was 1 inch high (should be .5 inch high) and the wingnut would hit the top of the hood. If you don't have a spacer then get the 14x3. And in the future, if you want to get a spacer, make sure you get one that is half a inch high ok? Help this helps.
Eric Natzke
91 Firebird 305 TBI (ZZ4 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-Accel Cap & Rotor
-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone
http://members.aol.com/j007golden/91firebird.html
Old Nov 3, 2000 | 08:31 PM
Hey thanks!
I still have a couple more questions though.
Did u have to plug or relocate any sensors or anything like that into the new open element?
I need to keep it emisions legal. Damned NY laws!!!
And how did u plug that tube that goes from the stock exhaust manifold into the stock air cleaner assembly inlet?
Old Nov 3, 2000 | 08:51 PM
Tas's Avatar
Tas
are those flat based? if not I wouldn't get one. you need to plug the tube coming from the bottom of the TBI. I just put a bolt in it. I keep my stock cleaner in the garagefor inspections every 2 years. There is one sensor ont he bottom. I think the K&Ns have a place for it. I just put mine on a spark plug wire in the back of my engine.
Old Nov 3, 2000 | 09:22 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Yeah, the K&N's have a place to put that sensor, (I belive its the IAC?) But all you do is drill the hole that have pre-dented for you and put it in there. Thats what I did. Oh and with these Open elements you can take that gold ring out from the tbi unit. You will know what I am talking about when u see it and just tighten it down onto the tbi. Thats what I did.
Eric Natzke
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-Accel Cap & Rotor-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone
Old Nov 3, 2000 | 10:27 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
The tube that goes from the exhaust manifold to the air cleaner inlet is a heat riser hose. Just yank that thing off.
The sensor your referring to isn't the IAC, it's a air temperatur sensor, I don't quit remember it's exact name. You can just relocate that somewhere else. you'll have to plug the vaccuum line coming from the TBI that went up to the air cleaner's thermac valve too since the open element won't have that.
BTW, the IAC is the Intake Air Control valve, it's what controls the engine's idle air supply, and it's located on the TBI itself, Eric
1992 RS
327, Modded TBI, Rebuilt WC T-5 5-speed, PRO 4 15" rims, Nitto's, 3.73's, SLP 1 5/8" headers, and a few other things.
Old Nov 4, 2000 | 12:16 AM
Zac's92's Avatar
IAT= Intake air temp sensor
IAC= Idle air control
just clarifying things
Zac Spalding
Old Nov 5, 2000 | 07:34 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Thanks Duke, I knew it was something like that. Guess I should lay off the MGD for a little bit.
Old Nov 5, 2000 | 08:18 PM
Thanks guys!
Just one more question.
If i yank that hose off that goes from the exhaust manifold into the stock airbox, wouldnt the exhaust now just come straight into my engine bay????:confused
Old Nov 5, 2000 | 08:29 PM
Tas's Avatar
Tas
no. that is just a heat riser not an exaust riser. it is a T pipe type thing that channels the heat from around the manifold into the snorkel of the stock air cleaner.
Old Nov 6, 2000 | 02:39 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
3 posts in one week of people completely confused about how to put an open element on.
I think somebody should make an extensively descriptive tech article.
I'll do tomorow.
Old Nov 6, 2000 | 11:43 AM
snflupigus's Avatar
to rainy and windy to do it today, soon, i promise. maybe i can find a garage to do take all the pics in.
Old Nov 6, 2000 | 12:03 PM
Tas's Avatar
Tas
I got a tech article: go to the store, buy one, get a flat based one, put it on in the parking lot, relocate sensors, plug the vaccume line on the front of the TBI, leave the tube in the valve cover or buy a breater to replace it, don't leave the lot till its done. If it doesn't fit then take it back. I went through 3 3rd times the charm
-Tas
'89 Formula WS6
305, TBI, auto, 14x3 chrome flat based open element with K&N, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
ICQ 82881207
Old Nov 6, 2000 | 03:21 PM
pianiy's Avatar
I think everybody who has a TBI wants to do this mod (me included) the problem is that we generally know what we want to do but don't know how to get there... things like part numbers would be GREAT and specific dimensions as were mentioned earlier like the size of the element, the air filter, etc. And I haven't seen an article yet that has detailed what to do with the thermac line, air temp sensor or the PCV valve. And lots and lots of pics!!
'91 Firebird
305/TBI/700R4/T-tops
Mods: Catco high flow cat - B&M Shift kit - Taylor 8mm Spiro-Pro's - ACDelco Rapidfire Plugs - K&N Air Filter - Trans Am tail light conversion
Stereo: Pioneer DEH-P8200R - Pioneer 6x9's - Kenwood 8" Tube
'91 Pics
'87 Firebird
2.8L/MPFI/700R4/220K Miles on its original, never been rebuilt engine!
Car being parted and sold, just ask what I have.
'87 Pics
Old Nov 6, 2000 | 03:30 PM
Tas's Avatar
Tas
the best way to learn is to jump in with both feet. If you make a mistake then you won't do it again. No amout of details will cover EVERY situation. and all those other corny saying....
Old Nov 6, 2000 | 04:20 PM
ethan71's Avatar
I'm about to swap mine for an open element, and a tech article would certainly help, especially with pics, so I know what an IAC is and what to do with the darn thing. This will be my first mod, along with new headers (what kind do you recommend) and a Flowmaster cat-back. I don't know what to do with my cat though. I need it to be legal, but it takes up too much power, should I get a new one?? (emmissions is in January). What about rear end?
Ethan
'88 T/A
305 TBI with T-5
40,000 miles (winter stored)
Old Nov 6, 2000 | 05:50 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
I can take some pics this weekend and post them. It really isn't that hard. Took me about 10 minutes I think, it wasn't long. I will try to get some pictures if someone doesn't do it by the end of the week
Eric Natzke
Brinkkl2000
Aug 4, 2018 08:29 AM
NiG
Sep 7, 2015 11:25 PM
Wife'sCar
Sep 5, 2015 08:58 AM
wruiz
Aug 13, 2015 09:07 PM
