SLP Headers for 305 TBI
Old Dec 6, 2000 | 04:42 PM
Turbo Bob's Avatar
Is anyone currently using SLP headers and Y pipe on their 305 TBI engine and if so are you satisfied with the results if any results at all? Also need the SLP part numbers on the listed parts and the difficulty of installation. Along with this what would be a good after market cat. to use with this system, and did you use the 1 5/8" headers or the 1 3/4" headers?
Turbo Bob
Old Dec 6, 2000 | 05:28 PM
rsilver's Avatar
See my post on the exhaust board.The Slp's went in as easy as possible but take your time. I used the 1 5/8 and gained a lot in the upper end and lost a lot below 3,000rpm.
Plan on adjusting your fuel pressure. I assume you are going 3" all the way back. I used a 3" catco cat from summit and a flowmaster muffler.Good luck........bob
91 camaro RS L03 convert,
t-5, ultimate TBI mods,TBI spacer,SLP 1 5/8 headers,
3"cat back, 3.42 torsen posi,alston SFC's,Global West LCA relocation brackets
Old Dec 7, 2000 | 02:13 AM
JPrevost's Avatar
Car: 91 Red Sled
I have the 1 5/8" and I never had it without them. The car pulls great in the mid range but low end isn't all there and the L03 just sucks at anything greater than 4200. So now I'm swapping in a 350 :-) The slp headers are great and street legal for NJ so even better.
, Jon (91 RS too many mods to list)
Old Dec 7, 2000 | 03:13 AM
WARDO's Avatar
They are easy to install, it just takes some time. If you are looking to do it quickly and need the car pay the extra money for the installtion kit and be sure to buy the cat adapter. If you can make it a weekend project and there is a parts store near by skip the install kit and get the bolt/misc. hardware gaskets from them It will be much cheaper. I am not sure about 1 5/8 headers but my 1 3/4's need to have a cover for the #1 spark plug wire, the wire will sit right on the tube. Most places sell an orange heat resistent material pretty cheap. Check them out at www.slponline.com
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
Dwayne614
Sep 28, 2015 08:33 AM
92purpz28
Aug 11, 2015 02:30 PM
