Vortec Heads
Old Dec 7, 2000 | 08:51 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Vortec Heads
If I get a set of Vortec heads, would I need a special intake?? Second, they are 64cc, I am building a 350, would I want 64cc??
Godti
'89 Trans Am (Red)
305 TBI 5spd
Old Dec 7, 2000 | 09:48 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
yeah you need a special intake, no question about that. i used the edelbrock performer vortec intake and it worked good for me.
they should be 64cc as far as i know. i know mine are. unless they were milled or anything, they will be 64cc.
with a 350, 64cc heads will give you a 9.1:1 compression ratio, which is pretty good.
any questions about tne intake or anything, let me know. or check out my website in my signature. there is some info on there.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, SLP 1 3/4" Stainless Headers, Edelbrock Victor Series Water Pump, Accell Superstock Wires, Cap, and Rotor, MSD Blaster Coil, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
Brian's 1991 RS
Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
Old Dec 7, 2000 | 01:24 PM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
What type of compression do you want with a 383 stroker?? Will vortecs work with a 383??
Old Dec 7, 2000 | 01:34 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
I'd shoot for right around 10:1 (no less than 9.5, no more than 10.5). Yeah, they'll work with a 383. The compression here will depend most on what pistons (dish, dome, or flat) you choose for the build-up.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Dec 7, 2000 | 05:53 PM
Basett Racing's Avatar
2 valve-relief flattops (-5cc) w/ a Fel-Pro .038 gasket will yield 11.1 : 1. I just built an engine with this combo. If this were going to be a "driver" I would use either 4 valve relief flattops or .060 head gasket with 2 valve relief flattops - if they were aluminum heads, I wouldn't worry much about the 11:1, but with the cast iron Vortecs, I'd try to stay around 10-10.5 max w/ at least 93 octane as higher comp ratio will be prone to detonation.
Old Dec 8, 2000 | 12:28 PM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
You can check out Jim Pace perfomance parts for Vortec heads that hiave been drilled for the standard Intake pattern. they are extra but not too bad. I think it's 484.00 for the set ASSEMBLED. I think the springs are good to .500 lift too!!! A general rule is that you lose 1cc for every .004-.005 you mill of the head. Just a little info for you pocket book . Oh by the way vortec specific intakes are usually around 200 bucks
later,
Lars
Old Dec 18, 2000 | 02:41 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
someone had said earlier that the drilled heads dont bolt up very straight to standard intakes, something about the ports being off. Id stay with the vortec specific intake.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
Old Dec 19, 2000 | 05:30 PM
1982Camaro383's Avatar
I have a 1982 Camaro with the drilled and tapped vortec heads. I am using the Edelbrock RPM Air-Gap manifold. I had no problem lining things up.
Thanks,
Justin
1982 Camaro 383
http://www.fbody.com/members/82Camaro
Old Dec 20, 2000 | 06:44 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Thanks,
Justin
1982 Camaro 383
I checked out your site, thats an afermarket rad, right?? Did you need the Rad for the 383 or you just decided to replace it?
Old Dec 20, 2000 | 01:13 PM
The radiator is a custom aluminum radiator, with two large electric fans. It keeps the engine running cool along with my Sanderson Cast Iron headers.
Thanks,
Justin
1982 Camaro 383
Old Dec 20, 2000 | 08:41 PM
Hey, Justin I saw my car on your site, thanx, man.
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
http://www.bassettracing.cz28.com
Old Dec 21, 2000 | 06:20 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Which is yours??
Old Jan 4, 2001 | 11:10 AM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
The ports line up just fine. If you use the Vortecs on a 305 you have ti mill them then you have to use a specil adapter between the intakeand heads justbecasue of the gap. But other than that there is no difference between the ports.
Later,
Lars
Old Jan 4, 2001 | 04:30 PM
Godti,
The black 82 Z28 with the Convo Pros on the "Cool Third Gen Page"
Best ET: 12.52@107.2
New Best ET: 15.03@92.7 http://www.bassettracing.cz28.com
[This message has been edited by Basett Racing (edited January 04, 2001).]
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
