I did some updating! let's see yours!!
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Ok guys I needed to cheer myself up after all the egr mess I've been going through so I decided to clean up the engine bay a bit.I know we have some"Let's see your TBI engine bays" posts but it's been awhile since we've had some updated pics.Let's see what new with the Tbi crowd!! So, show me some new stuff guys!
Car: 1983 G20 Chevy
Transmission: 4L60
I did some updating recently too. Along with the Heads/Cam swap I went with this baby.
It has gone 9.3 @ 74 in the 1/8 with a 2.08s 60'. That is not bad for a Goodwrench 350 TBI, Ported TPI heads (1.94/1.60 valves), 9.85:1 compression, mild cam, Edelbrock 3704 TBI, 46mm TBI unit, and 1 1/2" primary headers. All in a 5,300 lbs Van with 3.07 gears.
Car: 92 RS Camaro
Engine: 305 TBI
Heres a pic of my L03 i just finished, ill get some pics of the finished engine bay soon. Ultimate tbi mods, edelbrock performer intake, crane powermax 2032 camshaft, ported and polished 081 heads.
Dammit! Hit the edit button instead of the quote button! Hope none of the post was lost
Car: 1992 Camaro RS (Z28 Clone) Z03
Engine: 305 TBI
Axle/Gears: Eaton POSI/ 3.73
Hey FAST355 I'm liking the Cadillac air cleaner. Lol. Looks good though. I got a question for you, do you have an aftermarket throttle body. If so what brand and what kind of horsepower increae did you get from it? Also was the throttle body spacer worth any horsepower?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Heres mine. It has the nylon/resin composit carb hat that extreme velocity used to make. Shame they still dont make it. The rest is a 350 with vortec heads, holley 670 TBI, edelcrap performer plus cam (204/214 .420"/.442"), 3" exhaust, 3.5" intake, etc. Doesnt wind real high. Only thing its really good at is turning the car into an unguided missle in first and breaking stuff. Still lots of fun on the street, though.
Car: 88 Camaro SC
Engine: SFI'd 350
They still have the hat in aluminum, but its pricey. They also may still include the internal baffle, which would have to be cut out if using on TBI.
Car: 1983 G20 Chevy
Transmission: 4L60
My TBI unit is not an aftermarket piece, but it was bored over by Tom Bishop @ Extremefi. It is 46mm and has had the top flat milled and chamfered.
The TBI spacer was a cheapy used one (for a 454) that I found on ebay. I think I paid less than $10.00 shipped to my door. I ran it as is for a while with a 454 TBI unit on it. I then pulled it off, cut the center out of it, smoothed everything out, and put it back on with the 46mm SBC TBI unit. I have since had the loose shaft 454 TBI unit bored to 54mm and bushings added to tighten the throttle shafts back up. The re-conditioned TBI unit really helped my idle quality by eliminating a fairly bad vacuum leak around the TBI shafts.
Car: 88 Camaro SC
Engine: SFI'd 350
What belt line will you be using with those valve covers? I used the standard permiter bolt ones with mine and I had to beat the snot out of the pass. VC to get it to clear the alternator on my serp. system.
Car: 92 RS Camaro
Engine: 305 TBI
Ill have some more pics soon Thread Starter
Come on guys I KNOW there's more of us than this! show off guys.
Car: 91 RS
dimented24x7..................I had to turn the rear housing of the alt to get enough clearance to the battery connection which is the only problem that I had. I have a pic but cannot get the attachment link to work.
Oh well..........
Happy New Years
Oh well..........
Happy New Years
Car: 92 trans am clone
Engine: LO3
well its nothing special but nobody so far had nitrous on theres so i thought id put it up. sorry about the purge line not being there since i tried plastic(easy way) but it melted so i gotta get a new line. also i got a set of headers sitting up in my room at the moment getting ready to be put in.
Car: 88 Camaro SC
Engine: SFI'd 350
Thats actually a really good idea. Ill have to remember that.
Last edited by dimented24x7; Jan 2, 2007 at 12:15 AM. Reason: Automerged Doublepost
Elephantismo
Feb 13, 2019 12:51 AM
2012sergen11
Oct 13, 2015 07:38 PM
Because it is... J/k lol
