Need Help (re air cleaner size)
Old Jan 17, 2001 | 06:59 PM
1989CamaroRs's Avatar
im gonna order an open element filter for my car and i need to know what the tallest air cleaner is that i can fit on my stock 305 and stock hood. Also need to order an offset one right? for hei thanks
-Stock Tbi 305 with a lot of damn miles
-Edelbrock Z28 TES Headers
-3 inch Catco High Flow Cat
-3 inch Edelbrock Catback
Stereo
-Pioneer DEH-P4100 cd player
-Polk Dx9 6x9s
Old Jan 17, 2001 | 07:59 PM
Andy89RS's Avatar
I'm not sure what you mean by offset, but what you need is a 14 x 3" non-drop base. To make it fit you remove the spacer ring, and you end up with a perfect fit under the hood. 14 x 4" would be too long for the stud, and would most likely also hit the hood.
Old Jan 17, 2001 | 08:54 PM
Keith5's Avatar
Car: C1500
So what we need is a non-drop base? I have been under the impression that it was a drop base.
1989 Pontiac Firebird
Formula W6S LO3 TBI 305
-180 degree stat
-Hooker Cat-Back
1985 Camaro IROC-Z LB9
http://www.geocities.com/krt80/
Old Jan 18, 2001 | 09:44 PM
Andy89RS's Avatar
Well with a non-drop base you remove the spacer ring on the TBI and get a perfect fit. With a drop base, you leave the spacer on. Using a spacer to lift the air filter, and then getting a filter base that drops to make it fit right is kind of self-defeating, not to mention you get slightly more restriction and turbulence with a drop base.
Old Jan 18, 2001 | 10:10 PM
Keith5's Avatar
Car: C1500
So everything fits like that? No bending or modifying anything to make it fit? Why do some others use the drop bases?
[This message has been edited by Keith5 (edited January 18, 2001).]
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
ill reiterate SLIGHTLY on that turbulance thing. So get either. Read the open element filter tech article.
Old Jan 18, 2001 | 10:50 PM
Keith5's Avatar
Car: C1500
Will any non drop base cleaner fit the TBI unit? Without the spacer does it fit exactly?
Old Jan 18, 2001 | 10:55 PM
snflupigus's Avatar
yes. and yes, sometimes depending on brand of nondrop, ive heard of some hitting the throttle linkage.
Old Jan 18, 2001 | 11:18 PM
Keith5's Avatar
Car: C1500
go to partsamerica.com and look up this air cleaner part # 4762 . that looks nice
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
