46mm tbi on edelbrock performer tbi
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I have the extremfi 46mm tbi, the bores on the performer tbi are 43mm. Its going on my lo3 with full exaust, free ram air intake and coustom chip.
Is it worth boring the performer tbi manifold bores to 46mm?
Id really appreciate your opinions.
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
The air will bind up.. So you might want to do something... whether you bore it out to 46mm or kind of make the manifold Throttle Bores get a V shape to get the air to flow better... and when/ if you make the V Cone shape, try to leave it a bit rough, i think that it may help with atomizing the fuel... However im unsure.. so wait till someone else posts.
Just My 2cents....
Just My 2cents....
Car: 1983 G20 Chevy
Transmission: 4L60
Personally, I would chamfer the edges of the bore and leave it. If you were going with a 50mm, I would step up to a 50mm bore in the intake though.
Car: 91 Trans am
I dremmeld the bores all the way in and finished with a file.
Now it is pretty rough like the casting surface. Is that to rough? Id like to post some pics but i dont know how.
Using the stock cilinder heads, correct me if im wrong, I think the 46mm tb and the chamfered performer will not be restrictive.
Car: 1991 Camaro RS
I'd add 1.6 ratio rockers to take Full advantage of the extra Air and fuel.. I think youd want some rough edges to help with atomizing...
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Car: 91 Trans am
But first I need to find some more information on how to do the job cerrectly.
I dident leave any ruogh edges, its just that the hole surface isent as smoot as before.
Car: 1991 Camaro RS
Well if you got Something Fine grit and hook it to the dremel and work its way smoother.. I dunno.. Depends how how rough it actually is.. I dont think there will be any air binding..
Hotrodboba400
Dec 10, 2019 07:07 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
