i have my T5...now what other parts do i need to complete a tranny swap
Old Jan 30, 2001 | 04:01 PM
big tex's Avatar
I have have a T5 on the way...i know i need a clutch (obviously) and what else do i need. slave cyl? please help me out if you know anything.
1992 305 TBI RS
Flowmasters...basicly stock with interests to modify
Old Jan 30, 2001 | 04:29 PM
ONEFINE8T9's Avatar
bell housing, clutch fork, pilot bushing, clutch master cylander and all the lines. Ur best bet is to go to a junkyard and find a T5 f bod. just grab all the stuff u need off that. I am not exactly sure, BUT u might need a different crossmember.
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
Old Feb 2, 2001 | 12:17 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You also need a new starter. Either a stock unit for a manual tranny equipped car (along with the new 1/4" shorter mounting bolts) or a mini-starter which will work for either an automatic or manual equipped car. Also this topic should be moved to the transmission/drivetrain section. Good luck, Lon. 8^)
[This message has been edited by lonsal (edited February 01, 2001).]
Old Feb 2, 2001 | 12:05 PM
ONEFINE8T9's Avatar
dont forget a fly wheel
Old Feb 2, 2001 | 06:10 PM
big tex's Avatar
the stock starter on my car wont work with a manual??? and by the way, this topic has already been on the transmission page with weak results. thanks, big tex
1992 305 TBI RS
Old Feb 3, 2001 | 02:06 AM
ONEFINE8T9's Avatar
naw ur starter wont work couse one fom an automatic is set up to be used with the "slimer" flywheel it has. If u look at a manuals flywheel its quite larger than the autos. So the starter deffinetly has to go. It sux too couse the 5 spd starters always seem to be much more in price than autos
Old Feb 3, 2001 | 02:31 AM
big tex's Avatar
ok...thanks for the info, so, what starter should I install. Aftermarket or OEM, and could I install it myself. What is the difficulty level. thanks, bigtex
1992 305 TBI RS
Old Feb 3, 2001 | 12:53 PM
Andy89RS's Avatar
Don't forget the pedal assembly and console. I have a Tilton mini-starter, and I highly recommend it. Saves weight, is damn near impossible to heat soak, and is a quality made in the U.S.A. part.
Old Feb 4, 2001 | 04:52 AM
ONEFINE8T9's Avatar
well for the few LBS u would save on a mini starter i highly doubt its gonna be worth the 120$ that most places ask for them. An oem starer would run u about 65$ and most will have a lifetime guarantee. give ur local auto zone a call. Man this was a bad night ................
sorry guys i gotta share my emotions
Terrell351
Jun 13, 2021 01:13 PM
1984HO
Mar 19, 2021 11:59 AM
Casey Meyers
Mar 2, 2016 10:46 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
