Do these TPS readings sound normal?
Old Jan 2, 2007 | 02:15 PM
y5mgisi's Avatar
Car: 90 Chev Suburban 4x4, 5.3L, th400
Engine: 2002 5.3 Vortec swapped in.
Transmission: Stock th400
Axle/Gears: 10blt front/ 14bltSF rear 3.73 gears.
I suspect that my TPS is going out. So i tested it today. This is what i got...
black/gray: 6.03v
Black and blue(closed throttle):.65v
black and blue(WOT)5.3v
That isnt exctly what they are suposed to be from the looks of some pages that i found searching here but i dot know if anyof those numbers actually tells me anything concrete.
Old Jan 2, 2007 | 02:22 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Off the top of my head, they look reasonable. 6 volts is a bit high for the reference. Should be 5 volts. What kind of volt meter are you using?
Old Jan 2, 2007 | 02:29 PM
y5mgisi's Avatar
a crapy old digital multi meter. I just actually found out that closed voltage should be .54 +/-.075 so idle is a litle off. And just to clerify, You cannot adjust a tbi tps correct? I think im going to go pickup a new multimeter and re test before i go out and buy a TPS (although this one does have 215k on it)
Old Jan 2, 2007 | 02:36 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Just as long as the readings arent too high, your ok. If it reads high or has dead spots, then its definatly time for a new TPS. Retest with a good DVM and make sure the reference is 5 volts and not 6, which would indicate a problem with the internal regulation in the ECM.
Old Jan 2, 2007 | 04:09 PM
y5mgisi's Avatar
Well i actually just ran up to the parts store to use the autoxray 6000 and that thimng says the tps at idle is .70v thats way to high id think. Also just got a code 42 it looks like.
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
killer777
Aug 8, 2015 02:47 PM
mustangman65_79
Aug 8, 2015 12:07 PM
