The tech board never helps, please help
Old Feb 11, 2001 | 04:10 PM
JPrevost's Avatar
Car: 91 Red Sled
Okay guys, this is my new problem. First off it's the 330hp crate engine with vortec heads. I wanted to get the rpm air gap just because of the future when I swap cams and make 380hp and 415 ft-lbs (compcam 122422). Anyways, you guys talk about the drop base air cleaner. My BIG problem is that I'm using the holley 670cfm TB and a 1/2" adaptor plate. I have the 5.0ho dual snorkel drop base air cleaner right now. Is that all the drop I need or what? Please Please help me, just give me an air cleaner that'll drop it low enough to fit under the stock hood.
One more thing. Is that 1000cfm edelbrock triangle looking air filter an option? It would be temporary. I'll be getting the ss hood this summer.
, Jon (91 RS too many mods to list), getting new engine in summer
Old Feb 11, 2001 | 04:42 PM
Tas's Avatar
Tas
that triangle thing is crap. Its foam and will break apart and fall in your engine. why not get a cowl hood? my original open element was 14x2-1/8 non drop base. that might fit. I got it in paper so I could figure out how high I could go before I got a k&n. I went from 14x2-1/8 to 14x3 eventually but I needed a longer carb stud since the top was barely conical.
Old Feb 11, 2001 | 06:08 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
drop base with spacer ring and 2.5 inch filter should fit. its not a big problem, youll just have to try a few, no matter what, its solvable after you drop in the engine.
Old Feb 11, 2001 | 06:09 PM
steve8586iroc's Avatar
I'm also very interesed in finding out how this will come out as I am putting a 350vortec engine with the rpm airgap manifold in my 91RS. I am contenplating a shaker type hood scoop. I just hate to think about cutting a hole in the hood. But I think it would look as good as it works. There is something about seeing you engine shaking or torqueing side to side when you rap the gas real quick.
Steve
[This message has been edited by steve8586iroc (edited February 11, 2001).]
Old Feb 11, 2001 | 11:28 PM
Basett Racing's Avatar
A shaker hood on a thirdgen 'maro??? hmmm that'd be different, but I bet it would be cool. If you do it post pics. If you're unsure about cutting your's, a stock flat hood in a junkyard usually only goes for $40-$50, so cut it, and if doesn't look like you expected it to, put your old one back on
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET: 12.52@107.2
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 14.91 @92.9
Bassett Racing
Mid Atlantic F Body -82 Z28 Page
Old Feb 11, 2001 | 11:37 PM
JPrevost's Avatar
Car: 91 Red Sled
Okay, you guys all say solvable AFTER the engine is in. What you don't understand is I'm 540 road miles away from home/camaro right now. I'm at school and over spring break I need to get the engine in and have her running and get her back to school. Keyword being "have," I'm working out in Columbus part time during spring quarter and then full time during the summer. So I would like to have all the parts at my house so I can just put the darn thing in and be done with it until I get it back to Ohio. So with that said. Where can I get a drob base cleaner with a 2"/2.5" element and a smaller carb stud? If you guys could get that info or tell me that that POS edelbrock is a sure fit that'll work for a 540mile drive :-)
Old Feb 12, 2001 | 09:52 AM
Dan W's Avatar
Summit 1-800-230-3030
Chrome Plated steel air cleaners
The summit air cleaners are 14" in diameter, have a 3" open element(paper), and a recessed base.
sum-g3000 cleaner w/o logo $19.95
sum-g3001 cleaner with logo $14.95
This is the one I'm running on my car... I have about 1/4" of clearance when using the stock spacer ring.
1988 T/A,
9" Ford, 3.50 gears, Auburn posi, 700r4 -w- 2100 converter
350 .060 over with forged 1 pc rms crank, and forged TRW pistons, 9.5:1 cr
Factory GM heads Pocket ported, 2.02/1.60 valves, back cut
Lunati roller 219/227, .479/.480, 112 LSA
Holley 700cfm 4bbl on TBI truck 7747 computer and chip by Howell-EFI
Edelbrock Performer EGR intake, Edelbrock TES and 3" cat
Old Feb 12, 2001 | 06:44 PM
JPrevost's Avatar
Car: 91 Red Sled
Thanks, I didn't want to front $56 for the K&N, good thing the summit is drop base.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
red90IROCls1
Aug 25, 2015 06:56 AM
IROCZ1989
Aug 19, 2015 08:15 AM
