help with timing adjustment? Angle
Old Jan 10, 2007 | 01:53 PM
635csi's Avatar
hi friends,
I need your help to finish timing adjustment with timing light on my 88 tbi camaro. I need to know in with part of scale ( 12 8 4 0) I must adjustment my car distributor, Also I need to know angle for timing light. Also I need to konw at what rpm must I make this?
thanks and regards from Spain
Old Jan 10, 2007 | 02:57 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I think it is in a sticky.
I time it from almost straight above the motor, but do it wherever you can get a good view of the timing mark, and tab.
Factory, is adjusted to zero. I had pretty good lucking advancing it to 4*. You need to time it at idle, with the ESC unplugged.
Old Jan 11, 2007 | 06:07 AM
635csi's Avatar
thanks for reply. last question what is it ESC?
bye
Old Jan 11, 2007 | 07:59 PM
deadtrend1's Avatar
bye
Its a brown wire located on the passenger side of the engine bay near the wheelwell, blower box, strut tower area. Has a little connector you unplug and then start the car. (this will set off the "Check engine light" and its ok). Then you set the timing. When your done, turn off the car, tighten your distributor, and plug the wire back in.
What unplugging the wire does is stops the vehicles computer from adjusting the timing, allowing you to set it to your "base" timing....
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
Linson
Aug 21, 2015 02:12 PM
86White_T/A305
Aug 17, 2015 12:16 AM
