Car stalls sometimes.... HELP
Old Feb 23, 2001 | 02:14 PM
92red'maro's Avatar
I have a 92 'maro RS, V8 5 speed.. sometimes when i start it up the engine dies, and when i try to restart and rev it the rpm's jump all over the place and still wants to stall, then after a few seconds it is fine. This doesn't happen all the time, so i have no idea what is wrong... any suggestions???
Old Feb 23, 2001 | 07:43 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
IAC, CTS, TPS In that order. Just a guess though.
Old Feb 28, 2001 | 11:24 PM
BigChevy342's Avatar
What does TPS Stand for and how can you adjust it or see if it's reading right?
thanks-
Old Mar 1, 2001 | 02:07 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
go to the tech article section. tps is throttle position sensor. its there. it will tell you how.
Old Mar 1, 2001 | 05:01 AM
speedlvr's Avatar
Hook probes of a volt meter to the a & b terminals on the tps harness with engine in run but dont start engine. Should read around .5. Adjust the throttle stop screw in or out to change voltage. BTW, I had the same problem and got an IDle Air Control valve today and it fixed it. Praise the Lode!
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
killer777
Aug 8, 2015 02:47 PM
