TBI/PCV/14X3
Old Mar 1, 2001 | 09:39 PM
Spyder's Avatar
TBI/PCV/14X3
Okay I have a 14X3 open element. So when I did the conversion I drilled a hole in the new air cleaner lid so I could put the I.A.T.C. (?) in it. Then I removed the breather and used a push in PCV breather on it. So now I am looking at putting on some nice, good looking valve covers. I was wondering, can I just plug the PCV tube on the TBI and not run a PCV or breather on the driver side head? Last time I tried just running a breather I had a problem with oil smoking out of the breather. I don't have a problem on the passanger side though where I used the PCV push-in breather (where is has the valve but looks like a breather). The new covers I'm looking at only have two holes, I would assume one for PCV and one for the oil cap (I hope) or how the hell do you put in the oil, here is the link. http://cgi.ebay.com/ebaymotors/aw-cg...393057&r=0&t=0
Old Mar 2, 2001 | 07:59 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
you should be able to plug the tbi pcv vacuum port, and then install breathers in both places. People have done it before.
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
U could have a machine shop just drill some custom holes u want for real cheap. It wouldn't take them long at all to do it.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Mar 2, 2001 | 05:33 PM
Spyder's Avatar
<font face="Verdana, Arial" size="2">Originally posted by snflupigus:
you should be able to plug the tbi pcv vacuum port, and then install breathers in both places. People have done it before. </font>
My question now is, would I run into any performance, premature wear with the TB unit, valves or motor?
Old Mar 2, 2001 | 06:12 PM
snflupigus's Avatar
must do regular oil changes or your oil will be come acidic and hurt your engine.
thats what i was told.
Old Mar 2, 2001 | 09:00 PM
FastBroker's Avatar
You gotta gotta gotta gotta run PCV in a daily/street driver. End of story, no more discussion, please.
Old Mar 2, 2001 | 09:01 PM
Spyder's Avatar
<font face="Verdana, Arial" size="2">Originally posted by FastBroker:
You gotta gotta gotta gotta run PCV in a daily/street driver. End of story, no more discussion, please.</font>
Okay then do you recomend just pouring the oil in through the PCV opening on the valve cover?
Old Mar 2, 2001 | 09:15 PM
FastBroker's Avatar
If that's how you need to get oil in ther for oil changes, that is fine. You need two valve cover holes:
AN EXHAUST hole, which always consists of a hole for the PCV valve.
AN INTAKE HOLE, usually in the opposite valve cover, which ALWAYS serves a a filter for the incoming air. It can be for a breather filter OR a grommet for a line to the air cleaner (to serve as the filter for the air for the pcv system).
Does that answer your question? PCV valves must be matched to the application, as they have different spring rates and total flow rates, which many do not know. As proof, look at the bottom of the PVC valve and you will see a letter code, which I believe is for TOTAL FLOW, but I'm probably wrong. Could be spring rate. Can't remember...
EDIT: and DO NOT run a PCV valve without a breather!!!!!!!!!!!!!
[This message has been edited by FastBroker (edited March 02, 2001).]
