open air element, does size matter?
Old Mar 4, 2001 | 09:55 PM
Zar's Avatar
Zar
I have a 9" by 3" intake. Would a 14" by 2" be better? Just woundering because everybody seems to have one. thanks
92 Firebird
305TBI, Full exhaust, air intake, 16" wheels, Tbi spacer
Old Mar 4, 2001 | 10:33 PM
speedlvr's Avatar
Your 9x3 has 84.78 square inches of surface area.
A 14x2 has 87.92 which is a 3.5% increase, not much.
A 14x3 has 131.88 which would be a 36% increase over what you have now.
If you are buying a K&N, the price difference for example between an 11x2 (what I had) and a 14x3 (what I have now) is about 4 dollars. In my opinion a 14x3 would be best. It cost me $42 at Auto Zone.
Old Mar 4, 2001 | 11:22 PM
Spyder's Avatar
There maybe more flow ability but to tell you the truth I could never tell the differnce when I switched. I had an old Spectre (?) that I got for 10 bucks a long time ago and then I switched to a K&N setup. Little, tinny differnce.. Was it worth the 50 bucks, no. Does it look cool, hell yeah (my car is red too so it matches the motor bay)
--Spyder--
1992 Camaro RS
LO3, T-56,centerforce clutch, ported and polished heads, Edelbrock Performer Intake, 14X3 Open Element w/ K&N, hiflow cats (and thats it), AC delete, alu drive shaft, 3.73 posi, 170 stat w/ fan switch, STB, Subframe connectors, KYB AGX, Eagle GSC, and poly bushings.
1982 Z-28
Project car, ZZ4 in the works.
Old Mar 5, 2001 | 07:31 AM
88firebirdTBI's Avatar
go to 14 inch element. more air, more power
Old Mar 5, 2001 | 07:51 AM
NJ SPEEDER's Avatar
the more mods you do that make the engine want more air the more important the 14x3 will become. i would say just buy the biggest you can fit right off the bat then you'll be ready for more.
lata
tim
91 Camaro RS-LO3,Auto.
14.215@94.30 w/ 1.917 60'
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Mar 5, 2001 | 09:53 AM
El Guapo's Avatar
Seems like the current thread of logic is bigger is better. That doesnt seem right to me.
It should be based on logic. How much air does the engine need? Of course, the mods will increase the Volumetric Efficiency (VE) of an engine. So lets assume you have everything dialed in and you actually achieve 100% VE (Average for a moded engine is ~85%)
Lets also assume a redline of 7K. Your engine will use 305CI of Fuel/Air every two RPMs so at 7K youre using (305 * 3500) = 1067500 CI of F/A a minute. now to convert to Cubic Foot Minute you divide 1067500 by 12^3. 1067500/1720 = 620.6 CFM.
Therefore l believe the real question should be can a 9x3 filter flow 620CFM? If so, then you are set till you get a supercharger or turbo that make your VE actually greater than 100%.
lm not sure on the flow of air calculations, so l cant say if the 9x3 will flow. But thats what you need to find out.
Clayton
Old Mar 5, 2001 | 11:11 AM
FastBroker's Avatar
Filters get dirty over time, guys, and therefore, flow less. ALWAYS get the biggest you can reasonably fit, for the price, in the vehicle. I run 2 stacked 3x14's (non-stock hoods/scoops/customs) in all the vehicles I run blowers (or off-roaders) on and at least a 3x14 in NA vehicles.
BTW, K&N's are great, but for the money, buying a FRAM 3x14 and changing it every year is fine for MOST performance engines I have seen here. I say this because most people I know don't take the time to properly clean and re-lube their K&N's, unfortunately, because it's easier and cheaper to just drop a new filter in...
Old Mar 5, 2001 | 04:26 PM
JPrevost's Avatar
Car: 91 Red Sled
True, get the biggest that fits because you'll have less restriction at higher rpm because of the extra surface area.
, Jon (91 RS too many mods to list)
Old Mar 7, 2001 | 12:38 AM
Zar's Avatar
Zar
Thanks guys!
Old Mar 7, 2001 | 01:14 AM
The ODB's Avatar
it is extremely important to have at least 3" of space above the mouth of the carb or TB so the air can make a smooth turn. Otherwise your flow will be decreased greatly no matter the diameter of the filter. Other than that, bigger is better, and cooler is best. Cool air makes more difference than just more air.
Brinkkl2000
Aug 4, 2018 08:29 AM
toronto formula
Nov 10, 2015 06:17 AM
wruiz
Aug 13, 2015 09:07 PM
knight72
Aug 10, 2015 09:32 PM
