Heated O2 Sensor-What do you know?
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
I am adding headers and I heard that a heated O2 sensor will reduce the time the car takes to switch from warm up mode to normal operating mode. What O2 sensor do I need? Who makes it and what is the part number? Has anyone done this?
Black 1989 RS Convertible w/43,000 mi.
Excellent Condition
LO3 305 w/TBI
12 PSI Fuel Pressure
6* Timing Advance
MSD Coil And Wires
Open Element 14x3 K&N
Hypertech Thermomaster
160 Degree Thermostat
Low Temp Fan Switch
Eddlebrock RPM Muffler
No Cat/No AIR Injection
B&M Stage 2 Shift Kit
17"x8.5" ATP 5 Spoke Alloys
P 245/45 Goodyear Eagle
HP Ultra Plus Tires
Lakewood Control Arms
Lakewood Pan Hard Rod
Coming Soon:
Hedman Headers & Y Pipe
12 Bolt With 3.73 Gears
NOS System
Excellent Condition
LO3 305 w/TBI
6* Timing Advance
MSD Coil And Wires
Low Temp Fan Switch
HP Ultra Plus Tires
Coming Soon:
NOS System
Car: 91 Red Sled
You should already have an 02 sensor if you have TBI. If you took it out then your car would be running like a ford (POS).
, Jon (91 RS too many mods to list)
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
<font face="Verdana, Arial" size="2">You should already have an 02 sensor if you have TBI. If you took it out then your car would be running like a ford (POS).</font>
they are out there man, but i dont think that they are that popular. they do work to get the car out of the "warm up" mode that you talked about. they are pretty expensive though. i was thinking about getting one for my car, but i think they were like 80-100 bucks. i thought SLP had one...maybe not though. i havent looked them up in a while. call summit or jegs...they will hook you up.
-brian
1991 Camaro RS - ultra blue metallic, t-tops
GMPP 350 HO crate engine - TBI, MSD ignition, SLP exhaust
700R4 - 2,400 stall converter, vette servo
10 bolt - coming soon - SLP zexel torsen differential, GM 3.73s
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
Car: 91 Red Sled
Hmm..that's funny because both my 86 and my 91 have the heated 02 sensor. I thought it might have come from the factory like that, my bad.
I should have seen the "heated" part, I read the post too fast.
[This message has been edited by JPrevost (edited March 08, 2001).]
Car: 91 Red Sled
http://www.tpis.com/pg37-40.html
Mid page there is the 3 wire sensor for $67. I'm not sure if that's over priced or not but I just ran into it so I thought I'd post a source.
I have a '91 with headers so I put a heated O2 sensor in it from a '91 Corvette. Everything worked out just fine. All you have to do is run a power and ground. They are about 50 bucks from any parts store.
[This message has been edited by VortecZ (edited March 09, 2001).]
Thanks a lot guys. I think I'll get one from my local parts store.
Does the engine idle down much quicker with the heated sensor? I hate the way it revs so high on cold starts.
Excellent Condition
LO3 305 w/TBI
6* Timing Advance
MSD Coil And Wires
Low Temp Fan Switch
HP Ultra Plus Tires
Coming Soon:
NOS System
Excellent Condition
LO3 305 w/TBI
6* Timing Advance
MSD Coil And Wires
Low Temp Fan Switch
HP Ultra Plus Tires
Coming Soon:
NOS System
Car: 91 Red Sled
Engine will rev up on cold starts the same way except it'll only last about 30 seconds compared to 90 with normal sensor. I guess when the previous owner gave me the car with the SLP headers he had the 3 wire sensor and through that into the whole package. My 86 maro didn't have headers but it had a 3 wire and I just replaced it with a single wire since it was such a POS anyways.
