Posi rear and 3:73's
Old Mar 8, 2001 | 06:00 PM
MurphsIroc's Avatar
Hey guys, Do everyone think that this is a good start to a Basically stock lo3 Iroc-Z?
I have a Flowmaster 80 series Muffler and an open element air filter. Just want to know If i am heading in the right direction to hit MID 14's. Thanks alot everyone!
Old Mar 8, 2001 | 06:14 PM
chevyboy07 91's Avatar
3.42 is the ticket for you right now IMO
Old Mar 8, 2001 | 07:35 PM
NJ SPEEDER's Avatar
3.73's are the answer according to math and the track. 3.42's will help but won't get everything out of the car like the 3.73 will. it's worth another tenth easy.
lata
tim
91 Camaro RS-LO3,Auto.
14.215@94.30 w/ 1.917 60'
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Mar 8, 2001 | 07:39 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
3.73s are only worth a tenth vs. 3.42s?? wow...thats surprising.
i am getting 3.73s within the next couple weeks...NJSPEEDER is right...they work out math wise to get you down the 1/4 in the best time.
but it depends on other stuff in your setup..is your car an auto or a 5-speed? what mods have you done? what do you want to rev the engine to? things like that.
-brian
1991 Camaro RS - ultra blue metallic, t-tops
GMPP 350 HO crate engine - TBI, MSD ignition, SLP exhaust
700R4 - 2,400 stall converter, vette servo
10 bolt - coming soon - SLP zexel torsen differential, GM 3.73s
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
Old Mar 8, 2001 | 09:47 PM
Basett Racing's Avatar
You will actually feel the difference that the 3.73's in the seat of your pants more than probably any one other mod. Do yourself a favor and do the gears before any major engine mods like cam, heads, etc. High gears will make even a strong engine feel weak and gears will make a weak engine feel stronger.
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET: 12.52@107.2
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 14.91 @92.9
Bassett Racing
Mid Atlantic F Body -82 Z28 Page
R.I.P. Dale Earnhardt #3
Old Mar 8, 2001 | 10:26 PM
Black Bird's Avatar
I've had my 3.73's for about a month. MASSIVE DIFFERENCE First gear makes you glad you have a seat back, along with breaking loose on a pretty much stock LO3 in the 1-2 shift with an auto.
'92 Firebird 305 TBI
3.73 Posi
ASCD Ram Air Hood
14X3 K&N
'00 WS6 Exhaust
Old Mar 9, 2001 | 01:14 AM
ONEFINE8T9's Avatar
ya 3.73s are great in a 5 spd. I have had mine for about 700 miles and the difference from the gears is incredable.
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
Old Mar 9, 2001 | 05:50 PM
NUN's Avatar
NUN
WITH 373 YOU LOOSE TO MUCH TOP END AND PROBALLY ONLY BEABLE TO GO AROUND 80 MILES PER HOUR
Old Mar 9, 2001 | 08:21 PM
Black Bird's Avatar
<font face="Verdana, Arial" size="2">Originally posted by NUN:
WITH 373 YOU LOOSE TO MUCH TOP END AND PROBALLY ONLY BEABLE TO GO AROUND 80 MILES PER HOUR</font>
LOL. I've been in third gear at about 90-95, near red line. I figure by the equations on the main page, that the top speed with 3.73's is about 120-125 with a 700R4. For me, I don't go all out much, so I wanted the better off the line performance.
3.73 Posi
ASCD Ram Air Hood
14X3 K&N
'00 WS6 Exhaust
Old Mar 9, 2001 | 09:18 PM
NJ SPEEDER's Avatar
nun,
how do you figure that? i have heard people say this before and i would really like to know what the thinking is.
the way any person should select a gear is to figure it from what their mph is in the traps at the big end. then you choose a gear that will make that speed as close as possible to the rpm of your peak hp.
in any car of ours the highest gear you will hit on the track is a 1 to 1 ratio (3rd in autos and 4th in 5spds). that works out to a 3.73 being the best gear at least until you do a cam, which is really the only way to change the position of the powerband enough to possibly demand a new gearing.
lata
tim
Old Mar 9, 2001 | 11:31 PM
JPrevost's Avatar
Car: 91 Red Sled
Since we're on the subject I might as well ask a few opinions on rear ends. My current setup is going to be the 350ho with the peg leg 3.08 rear with auto. I was looking at the 12 bolts but they are over 2K for a ready thirdgen setup and that's a lot for a college guy. I plan on doing a cam swap to be making 380hp and 420 ft-lbs and then getting a much higher stall converter. I'm thinking I'm going to have to keep the stock rear end unit so I figured I'd get a girdle/brace, locking diff from powertrax, and 3.42 gears. Do you guys think the 3.73 gears would be a better choice? I will need the car for highway driving and even a few 540mile drives where 80mph is the norm.
, Jon (91 RS too many mods to list)
hectre13
Dec 11, 2023 08:14 AM
Reddeath210
Oct 6, 2015 08:20 AM
tcflint
Exterior Parts for Sale
Aug 26, 2015 05:45 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
AkDrifted
Aug 17, 2015 07:45 PM
