read please am i a dumb f*ck?
big problem here huge problem..... i didnt know where to post this but the TBI guys seem to be the most helpful for me except for kevin91z...
here is my problem i was changng my gasket on my exhaust manifold and lost a bolt so i used a substitute until i could get to the auto store well as torqued the bolt in it snapped and left some bolt in my head.. my question is can i get the bolt out or is this a machine shop job? and while i am at it should i just switch to headers? do any of you know how expensive this would cost in your area??? I will never be this f*cking dumb again...
Shawn
91 RS 5.0 TBI
14x3 open element.. i liked alot
160*stat... made my car run a lil cooler
msd coil and taylor wires ...not noticed
with split fire plugs... which suck switching to rapid fires soon..
removed rear hood seal.. runs much cooler i liked
accel cap and rotor... coming soon
coming soon 3.42's with slp posi.. my first big mod!!!
Clarion cd player 2 planet audio 6x9's 2 lanzar tweeters and one MTX 10" sub in a bandpass all running off 2 separate 200w amps
Shawn
91 RS 5.0 TBI
crap that sucks. is the bolt sticking out of the hole at least or is it broken down in the hole? if its sticking out, maybe you can use soem WD40 and vice grips. if you have a dremel you might be able to knotch it on top and make it like a screw using a screwdriver to get it out. don't make the notch too deep because you will weaken the sides the screw will be pushing against.
-Tas
'89 Formula WS-6
[soon to have Hooker 1-5/8" 50 state legal headers installed]
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
-Tas
'89 Formula WS-6
Super GRK_Taz World
AOL IM: superGRtaz
not sticking out it is in deep.... i am screwed arent i dude this sucks... i wanted to put my 3.42's on seems like something always f*cks up...how much do you think it would cost if it is stuck inside?
Shawn
Shawn
Sears sells a tool that you drill a hole into the bolt it expands into the hole and you twist it out. Take a look.
Mike Kenny
1991 Chevrolet Camaro RS 305 TBI
My Website
Administrator at Auto-Clubs.net
My Baby
Mike Kenny
My Website
My Baby
Maybe you can get some 305 TPI heads quick, port and polish them, and put headers on them
My friends and I tried to extract a bolt from an aluminum intake manifold. The bolt was weak zinc and wouldn't come out, it just shread every time we tried to do something to it. like dude said up there ^ you can drill it out and try to extract it. good luck.
[This message has been edited by Tas (edited March 22, 2001).]
dude i work at sears! hell ya but if its cheap when i go to the muffler shop maybe i'll put a exhaust system on since i saved up some money... i'll post some results tomorrow...
shawn
thanks for the quick replies...
shawn
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
<font face="Verdana, Arial" size="2">Originally posted by pimpintheRS:
</font>
</font>
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
thats how i read it too.
calm down kevin.
pimp, i would say you could get an extractor kit. you are not the first person in the world that has done this. I mean i never have, well not on heads, i popped the heads off my throttle blades. so if you find a tap/extractor, look and see if there is a 1/64" one with the kit. (im fzucked, you are just delayed)
good luck
calm down kevin.
good luck
Dude, I've done this before! Auto Zone or any other local parts shop should have a tool which is basically a handle with a large reverse threaded screw attached to it. Drill a hole into the bolt, then screw the tool into the hole (remember to turn it to the left 'cause its a reverse thread) Soon the screw will grip the inside of the hole in the bolt and it will start turning. Good luck.
'68 Camaro - Vortec 350
'91 Camaro RS - 305 TBI
You guys are nuts, man. Those tools are a last resort, IMO.
Go to a GOOD welder and have them quick-tack a smaller bolt/rod to the broken piece. Then, when it cools, the piece can be backed right out. This works best if the threads are not stripped/bunged-up, obviously...
You can also use a GOOD epoxy yourself if the broker area can be cleaned VERY well and epoxied to something. Just don't get opoxy on the threads, man...
<font face="Verdana, Arial" size="2">Originally posted by Andy89RS:
I read that to mean that except for us on the TBI board, you're the only one that helps him out.</font>
kick back killer(kevin) i do get MOst of my help from the guys on the tbi board but not saying i dont get help from others i simply put your name because you are one person who helped me out alot. dont go and get all kinds of people pissed off at me or anything like that. it was simply a compliment towards you and the rest of the tbi guys who have helped me out alot... thanks for all the advice guys i am going to start working on it as soon as it cools off. 1 hour to go AZ helps to warm your car up its already 90 outside..
Shawn
and i am still going to do my 3.42's!
Shawn
If you have an oxy-acetaline torn just cut it off. Like not through it but I think some of you guys might remember having to cut out the bolt. Just heat up the head, once it gets cherry then blast it! Sorry I get way too worked up over playing with torches.
Car: 92RS
Engine: 357
If you are going to use a bolt extracter your self just make sure you dont twist it off in the hole also, they are as hard as a drill bit and hard to remove when broken.I have a set of left handed drills that I use at work to remove broken bolts.Usually the drill catches and backs the bolt out for me.I allways drill a small pilot hole first(like 1/8").allso make sure if you drill any hole in the bolt that you center punch the bolt first so you dont go off center and into the head.Good luck.
Dave
Dave
kick back killer(kevin) i do get MOst of my help from the guys on the tbi board but not saying i dont get help from others i simply put your name because you are one person who helped me out alot. dont go and get all kinds of people pissed off at me or anything like that. it was simply a compliment towards you and the rest of the tbi guys who have helped me out alot... </font>
yea what joker said. just take it slow and dont rush and force it
1991 Formula WS6 305 TBI
K&N 14x3" Open air filtercharger accel-8.8's,coil,cap,rotor,module.
poly's here and there.
245/50R16 255/50ZR16
3"catco cat
3" Borla cat back
3.27 POSI(B&W)REAR DISC
STRUT TOWER BRACE(E-BROCK)
WONDER BAR(NEW)
ADJ PANHARD BAR(HOTCHKIS)
TRAILING ARMS(HOTCHKIS)
[This message has been edited by REDBIRD91 (edited March 23, 2001).]
3"catco cat
3" Borla cat back
WONDER BAR(NEW)
took the manifold backoff couldnt see the bolt thought about it and realized why dont i just give this one to the shop... i wussed out i wanted to show off my gun to my friend so we went shooting instead. the shop had my car done in 2 hrs. it cost me 101.95 to have the bolt taken out manifold gaskets changed and everything since i popped the gasket again... that is cheap compared to what some places wanted so i am still kind of happy more because my rifle is better then my friends...
thanks
Shawn
thanks
Shawn
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Man there is a lot of posts on this thread for just trying to get a bolt out.
Good luck with the bolt man.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
